I am only 4 years into cnc and it is at the serious hobby stage. I want to make some 3d stuff in limited quantities in steel and I want it to be more accurate than my RF45 clone- these things are the basis for doing this build. In a perfect world, I would have Brother Speedio but as the wife won't sign off on that just yet, this is the current upgrade.
As far as the design, I am trying to keep each major components at 700 lbs / 300 kg. It will also be bolted on a much larger subframe that will add considerably to the mass I expect the full mill with the subframe( still finalizing the design) will be around 2500 lbs/1130 kg. I got all my rails, thk and nsk 32mm ballscrews and basic materials for 2k so far. Add my time and spindle + electronics pneumatic draw bar and I hope to be well under 10k. I think if I can achieve this price point with the components I am using it should be a major step up from my current mill and hard to beat in terms of cutting ability, accuracy compared other mills in this price.
I am still tweaking the vertical column. 11x12x36 is the current dimensions and re enforced with large steel tube cast inside. Should be about 480lb with the steel inside. This is alot better than the 100Lb or so weight of the RF45 column but it could be bigger.
Most important, when I finish, I will know the machine inside and out and be able to maintain and fix it if need be. Modern VMC's can be very complex and expensive to fix and there is the learning curve. I also would rather start with new stuff than learning fix someone elses mess.
To your comparison with an RF45, I am not sure how familiar you are with these machines. The column is 7x9 tapered hollow cast Iron, as is the base. I can pick up and move the column, the base or the table by myself. The whole machine is only around 800 lbs/350 kg without the motor and stand. Going from a RF45 to this build will allow me to replace dovetails with THK linear rails, 3 times the mass and the room to fit proper sized ballscrews and servos.
I am still tweaking the vertical column. 11x12x36 is the current dimensions and re-enforced with large steel tube cast inside. Should be about 480lb with the steel inside. This is alot better than the 100Lb or so weight of the RF45 column but it could be bigger.
You brought up an interesting point on the steel rails. I tested a 1/2"thick piece a foot long cast at the bottom of a box mold placed on a granite surface table. It was dimensionally unchanged. The ground steel will be through bolted to the mold and cast in a horizontal position with the epoxy granite on top in the same manner as my test. We will see for the bigger piece. I guess I will scrape or grout as needed.
For my part, the biggest thing I am trying to work out is mixing 3 - 4 cubic feet of epoxy granite per pour for each section. I have planned for a total of 25 gallons.
Thanks for the challenging questions!
