588,342 active members*
5,217 visitors online*
Results 1 to 14 of 14
    Dec 2012
    194
    Skimpy Oil Skimmers
    Anyone have experience using the Skimpy 6" skimmer?
    I'm considering mounting one on top of the Tormach coolant tank. There is aprox 6" clearance between the top of the tank and the bottom of the coolant collection tray. The skimmer is only about 3"high.
    Your experience and thoughts are welcome.
    Feb 2009
    6028
    Re: Skimpy Oil Skimmers
    We had a couple of those skimpy skimmers, we wore them out pretty quick. Replaced all with the Wayne mini skimmers and seem to be lasting longer. Mind you, we run them 10 hours per day though.
    I've had one for just over a year, great addition to the Tormach. Thumbs up on this product.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Mar 2009
    1863
    I have a 9 inch Skimpy Oil Skimmer. I added it about a month ago. So far, so good. It's on a timer and it comes on at 2:00 AM and runs till 7:00 AM. It drains into a 3 pound coffee can.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Dec 2012
    194
    Thanks all,
    Rory I have a picture of your setup, it got me thinking.
    Steve hadn't thought of the timer, interesting
    Aug 2014
    257
    Yeah, I just ordered the 6” model. I only measure about 8” height on the tank so I didn't think the 9” model would be a good fit.
    The literature says the belt only needs touch the coolant surface so you only need enough length to cover your level fluctuations.
    I'm planning to put both the skimmer & aerator on a timer.
    Can't beat the price...
    Dec 2012
    194
    Steve, any chance you can share a picture of your setup?
    Jun 2006
    3063
    Quote Originally Posted by R.DesJardin View Post
    Which model do you use? I have one that looks similar, might be made by Abanaki, but it left an awful lot of tramp oil in the coolant and picked up a lot of coolant with whatever tramp oil it did remove. Kind of the reverse of what I expected.
    Mike
    The 6" belt unit, it's seems to do a good job. I run it on a timed outlet so it runs a couple hours a day.
    Jun 2006
    3063
    Thanks - did you go with the 3/4-in or 1.2-in belt width? Polyurethane/Kevlar belt or the cotton/silicone belt? I have a feeling the belt on my skimmer was most of the problem but don't know what it was made from.
    Mike
    Quote Originally Posted by MichaelHenry View Post
    Mike
    3/4" poly belt.
    Jun 2006
    3063
    3/4" poly belt.
    Thanks - Mike
    Dec 2012
    194
    Attachment 271250
    Got my Skimpy installed and works. I will have it on a timer to run at night then when it turns off an air pump will turn on and run to aerate the coolant.
    Aug 2014
    257
    OK, got my Skimpy installed …
    Attachment 271286
    They provide a nice length of tubing for the install.
    I decided to run it out the back into a 1 gal milk jug.
    Used a knock-out punch to make a 1 3/8” hole in the rear.
    Eventually I'll install a rubber grommet (1 3/8” X 1” X 3/32”) in there.
    Made a 2” hole into the top of the coolant tank for mounting.
    I used 2 ea 10-24 X 3/4” screws for mounting.
    There was enough meat in the lid to tap it for the screws so I can pull it easily.
    Plugged her in & oil started started flowing right away.
    Very quite operation. Can not hear that it's running.
    Definitely needs to be on a timer.
    I'm pretty happy with the results.
  1. Oil skimmers
    By hotiron in forum Uncategorised MetalWorking Machines
    Last Post: 08-16-2014, 05:14 PM
  2. Coolant Coalescent Skimmers
    By mci.cnc in forum MetalWork Discussion
    Last Post: 07-03-2012, 02:40 PM
