Been following this with interest and maybe reccomend from looking at your layout. Your oil sump(pan) I presume is what the bottom part is and for clearance you probably should go straight down the side opposite the push rods. This may give you the clearance for the rods and also the crankshaft counter weights.
Just a suggestion and keep it up.
John
