Re: Martin's RF30 Build
Originally Posted by
Alax7
Nothing wrong with overkill steppers, that's a lot better than under kill for sure. If you want to put those motors to use, you can always build a 4th axis or an atc and use them there, or maybe you have a lathe you want to cnc as well.
Actually, larger steppers often can not achieve the same speeds as smaller steppers. For most milling this may not be a problem, but it can be in HSM toolpaths.
