587,189 active members*
2,578 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > How do you use a test dial indicator to find a center
Page 2 of 3 123
Results 21 to 40 of 41
  1. #21
    Feb 2015
    174
    Re: How do you use a test dial indicator to find a center
    "edge finder at those speeds" WHAT! No no, no. We are on a different page here, No, edge finder does not spin in this case. Please be careful, I don't understand and that's ok. I have been wrong before, lol.
    stu
    Other than that I use a solid edge finder (a probe) I consider accurate. Tramming or truing up a part, vise or work piece I suggest an indicOL.
    Edit: indicOL, https://www.google.com/search?q=indi...Q&ved=0CDEQsAQ
    I have several, so nice and easy to use.
  2. #22
    Feb 2015
    174
    Its a par 29, the mine fields are out of bounds on the right and chinese communists are out of bounds on the left. M*A*S*H reference.
  3. #23
    Feb 2009
    6028
    Edge finders work best at 1k rpm. 6k will scatter them all over the place. 10k gets real exciting BTDT.
  4. #24
    Feb 2015
    174
    I use solid probes as I work in tool steel and setups need to be quick and reliable. Winding up edge finding probes result in a box of broken parts.
    underthetire, lol. 10k gets real exciting! Toss whats left in the damn box after you get it out of the chip conveyor. This is funny in a strange way.
    My 2 cents.
  5. #25
    Jul 2013
    608
    Guys, but how you get a spindle to run at 1K rpm. is this possible with a "real" spindle controlled by variable speed controllers?
  6. #26
    Feb 2009
    6028
    Most of the time I use them is in vertical machining centers, so yes 50-14k infinitely variable. That's where I miss typed in MDI 10k instead of 1k. Less than half a second from 0-10k rpm and nothing left of that edge finder. So quick even the beaver tail pucker switch wouldn't have stopped that one.
  7. #27
    35538
    There are different types of spindles. A spindle on a router can not be spun anywhere close to 1K rpm if you don't want to kill it.
    Spindles on mills can spin at very slow speeds.
  8. #28
    Jul 2013
    608
    I appreciate the help, but some of gents like to speak in code and its confusing.
    I just located the zero of a piece of alum. with a metal edge finder at 8 rpms and it was fine. Unfortunately I do not have a real spindle on my cnc router but that will be my my next upgrade.
  9. #29
    35538
    If your finding the edges of aluminum, use some probing routines and a piece of precision ground drill rod chucked in the spindle. Quick and easy.
    Look through this thread.
    http://www.cnczone.com/forums/mach-w...-software.html
  10. #30
    Jul 2013
    608
    Hi ger. In reality I need to be able to find the edges of any material I cut.
    Just an update, my edge finder broke at 8K rpms =( definitely the tool for a CNC router type machine. I need to invest in something else.
  11. #31
    35538
    How about this?
    The Makers Guide - Triple Edge Finder - THE MAKERS GUIDE
    Or, you can just hold an aluminum plate or angle against your edge and probe to that.
  12. #32
    Feb 2015
    174
    FoxCNC1 "Just an update, my edge finder broke at 8K rpms" LOL! Toss whats left in the box. Hope you won't need a bigger box in 6 mouths.
  13. #33
    Jul 2013
    608
    ^ every post you have made has been garbage. What the problem you trolling?
  14. #34
    Feb 2015
    174
    NO! I will back way off now. NO troll intended. I simply have no one else to talk to about this subject.
  15. #35
    Jul 2013
    608
    Quote Originally Posted by stucapco View Post
    Then please contribute information and NOT just make fun of the situation on every post.
  16. #36
    Feb 2015
    174
    Agreed.
  17. #37
    Mar 2015
    I wanted to know if the same method can be used to find the center of every type of dial indicator. I have bought a dial indicator from NRI parts ( https://www.nriparts.com/tools/measu...ial-indicator/ ) and I want to use it to find a centre. Can someone tell me if the process will be the same?
  18. #38
    Jun 2013
    1041
    Sorry you have the wrong type of indicator. What you need is a dial "test" indicator to use the methods mentioned.
    https://www.shars.com/product_catego...Test_Indicator
    The link is to the correct type of indicator. Stay away from the .0001 indicator it doesn't have enough travel to be easily effective. Stay with the .0005.
    Ben
  19. #39
    Jul 2013
    608
    Quote Originally Posted by bhurts View Post
    Ben
    I have to ask: what makes these devices more expensive than the next ? Why is a Mi tu too close to 100 bucks if not more
  20. #40
    Feb 2009
    6028
    Quality baby, and usually the higher end ones have jeweled movements. I have indicators that range from $200 all the way to $2150. Don't think i even own one that measures less than .0005. My $2150 one gets down to micro-inch or nanometer. Stick with cheap ones for now, the more expensive they get the more it hurts when you accidentally smash one.
Page 2 of 3 123
  1. Dial Test Indicator Flaw
    By Zirok in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2012, 08:04 PM
  2. Dial Indicator
    By hive8 in forum Benchtop Machines
    Last Post: 06-18-2012, 10:59 PM
  3. I really havent seen such behaviour of dial test indicator
    By Ashish B in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2011, 10:39 AM
  4. I can use a drum dial as a dial indicator can't I?
    By slashmaster in forum Benchtop Machines
    Last Post: 11-03-2010, 06:10 AM
  5. dial or test indicator for squaring/leveling linear rails?
    By margni74 in forum Calibration / Measurement
    Last Post: 09-19-2007, 01:45 AM
