Originally Posted by
engnerdan
Just so you know I did start down the path of designing a new head stock casting that would work with the larger 90mm spindle cartridge. If you want the solid model I could dig it up, otherwise I could take a stab at finishing it sooner than later. If we could settle on one design that would work for your needs and mine we might be able to save some money getting a couple cast instead of just one at a time.
As for the discussion on ball screws, I have measured and modeled the ball nuts from my Pro in Solidworks along with the Z axis and Y axis ball screws. I have not uploaded these to GrabCAD or any of the updates I have made recently. If there is a need I can send the files directly or upload them to GrabCAD. Some info I have found, Z axis is a 20mm (measured 19 mm OD) 5mm pitch right hand thread. The ball nut had the same dimensions (OD and bolt circle) as the cheap ball screws from Ebay. The X and Y ball screws are 25mm (measure 24mm) with a 5mm pitch and left hand thread. These too appear to have the same ball nut mounting dimensions as the cheap ebay ball screws, but those are right hand thread. Additionally I have only found a double ball nut available up to 20 mm on ebay. I have not tried contacting any of the vendors to see if they have a 25mm available.
-Dan
