587,404 active members*
3,340 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Turning - One Tool for drill and inside turning?
    Feb 2014
    31
    Hello Guys,
    I just want to use a Endmill for drilling holes and inside turning. I just try to define a bore tool, it works for inside turning, but i i want to you it for drilling a hole with a "bore", i get a error for using the wrong tool type!? Partmaster told me that i need a end mill, a bore e.g. ... but i have a bore!? whats the problem.
    thanks
    Apr 2003
    354
    Re: Turning - One Tool for drill and inside turning?
    Try defining a new boring tool and change its primary & included angles to 90 deg & -90 deg. Set your Hand & Approach to how you need them. Select that new tool number after completing the drill cycle and build your internal turning job from there. I think that will work.
    Feb 2014
    31
    Ok i tried it again, and now it works... i dont know why but it works. I has defined my end mill as a bore tool.
    but i have another problem now... i want do dril/turn inside this pulley. the smallest diameter is 8mm, the bigger one 10mm (picture)
    my endmill has a 4mm diameter, so the maximum deep of cut is 2mm. is my defined tool correct?
    Because i got this Code (working in Dia mode):
    % Rolleextra.NC
    N10 G54 K0.00
    N15 M60 D0.0 L0.0
    N20 G90
    N25 G21
    N30 Z70.0 X130.0 M09
    N35 M6 T18
    N40 S300 M03
    N45 G00 G40 X0.0 Z3.0
    N50 G01 Z-12.0 F50.0
    N55 G00 Z3.0
    N60 G00 Z0.0
    N65 G01 X-1.741
    N70 G01 Z-12.0
    N75 G00 X0.259 Z-11.0
    N80 G00 Z0.0
    N85 G01 X-3.482
    N90 G01 Z-12.0
    N95 G00 X-1.482 Z-11.0
    N100 G00 Z0.0
    N105 G01 X-5.223
    N110 G01 Z-12.0
    N115 G00 X-3.223 Z-11.0
    N120 G00 Z0.0
    N125 G01 X-6.963
    N130 G01 Z-12.0
    N135 G00 X-4.963 Z-11.0
    N140 G00 Z0.0
    N145 G01 X-8.704
    N150 G01 Z-2.55
    N155 G01 X-8.2
    N160 G03 X-8.0 Z-2.65 I0.0 K-0.1
    N165 G01 Z-12.0
    N170 G00 X-6.0 Z-11.0
    N175 G00 Z0.0
    N180 G01 X-10.445
    N185 G01 X-10.2
    N190 G03 X-10.0 Z-0.1 I0.0 K-0.1
    N195 G01 Z-2.55
    N200 G01 X-8.704
    N205 G00 X-6.704 Z-1.55
    N210 G00 X-3.604 Z0.0
    N215 G00 X0.0
    N220 G00
    N225 M30
    Attached Thumbnails Attached Thumbnails Bildschirmfoto 2015-03-18 um 17.40.12.png   Bildschirmfoto 2015-03-18 um 17.42.44.jpg
    Feb 2014
    31
    but i get an diameter of 11,55mm and 13.55mm .....whats wrong?
