587,546 active members*
3,717 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Plasma, EDM / Other similar machine Project Log > Plasma Table Build Log Including Free Plans Link, & Pictures by Weldtutor
Page 22 of 22 12202122
Results 421 to 433 of 433
  1. #421
    Aug 2009
    60
    Quote Originally Posted by Weldtutor View Post
    This name sign was cut for the desk of a person who works with fire! (flame2)
    Great looking piece with exception to the surface finish. What is the deal with all those loops? Do you eventually buff them out?
  2. #422
    Oct 2005
    1238
    Arrow Swirl Finishing
    Quote Originally Posted by pinjas View Post
    Thanks for your interest.
    The finishing method used for the above 2 desk names results in a very attractive surface, although it reflects light & will not photograph well at all.
    A fine disk is used to polish, followed by adding swirl marks with the edge of a 4" coarse grinding disk.
    This is followed by clear or translucent coloured lacquer which enhances the swirl effect.
  3. #423
    Apr 2006
    3498
    Weldtutor..
    I am really impressed for the Flame sign... Whenever i saw your new work i am mesmerized..
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  4. #424
    Oct 2005
    1238
    Arrow Thanks
    Quote Originally Posted by Khalid View Post
    Thanks for the comment.
    I'm pleased that you like the flaming sign!
  5. #425
    Mar 2010
    How Can i use a hand torch in (LGK8-100) cut throgh 20mm. in acnc table. pls. any help for that ?
  6. #426
    Nov 2008
    11
    call me at
    0101405249
    or
    0117080734
    mohamed alhawary
  7. #427
    Oct 2005
    1238
    Cell will not connect to that #.
  8. #428
    Oct 2005
    1238
    Smile Still Working Well
    Six plus years & this table, with chain drives, continues to produce high quality results. :banana:
    Large dolphins are 22" long & smaller ones are 1/2 scale.
    Files are modified versions of downloads.
  9. #429
    Apr 2006
    3498
    Thanks God ou are alive again. Nice work as usual? Where were you by the way?
  10. #430
    Oct 2012
    Software
    Hello Weldtutor, very very good post, I think I didn't read al the comments, maybe is a subject you talked in some of the comments, but could you tell me wich software coul be used to control the table ?
    thanks
  11. #431
    Oct 2005
    1238
    Arrow Software
    Hi MecatronicsBoy,
    Welcome to CNC Zone!:wave:
    The software used to control the plasma table is MACH 3.
    WT
  12. #432
    Jun 2003
    Re: Z Axis Progress
    Hello Weldtutor and fellow Canuck. (although I now live in the US) :-) Do the torch plate bearings actually ride on the work?
    Thank you
    Tom
  13. #433
    Oct 2005
    1238
    Re: Z Axis Progress
    Hi Tom,
    Yes, the transfer bearings on the underside of the torch plate do actually ride on the work surface.
    This works quite well & in posts #184 & 281 there is additional information you might find helpful.
    Pictures in posts #48, 112, 285, & 363 also show the torch plate & bearings.
    The springs on the plate mounting bolts compensate for work surface irregularities.
    WT
  1. Free Plasma Table Plans
    By mlaws1172 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-24-2020, 03:11 AM
  2. CNC Plasma Cutter Table Build 3x2m including THC and watertable
    By AndiKid in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-16-2018, 11:02 PM
  3. Need link to 4 x 8 table FRAME plans
    By MetalHead6263 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-23-2011, 05:00 PM
  4. Free plans Router table Thanks, But help
    By aircub in forum DIY CNC Router Table Machines
    Last Post: 10-16-2005, 08:14 PM
