Re: I want to cut slightly further than the model
Originally Posted by
mountaindew
I did not think it could be a fixture problem!!! If you can place and use fixtures in your cam models your experience is well above beginner and setting the most basic values in water line operations. As I mentioned above if you change bottom level value it will go to that depth! Not clear why you cant. I would need picture of setup and ucs defined and where. If ucs is set to bottom of part then the value would be different then top of part! Many factors, I would watch all the tormach videos as many times as it takes to learn setup and basic operations. Then build on those skills a little at a time. This is complex powerful software that can run a large verity of machines, kludges and bodges as you mention above are not required and its more a function of understanding cam software. As drutort mentions there are a number of ways to do the same thing or control what your doing or what the software is doing.
md
thanks, having my "fixture plate" not as a "fixture" was what was stopping waterline working as it should and being able to cut below the lowest point in the parts, I had left it in place as initially i was having to align the fixture plate to X0,Y0 in SC, but now I am a bit more confident in not having that there.. SO much to learn, it can be frustrating when you are trying something that should be easy..
Sliding down the razor blade of life.
