588,496 active members*
4,365 visitors online*
Results 1 to 15 of 15
    Nov 2012
    130
    Vise jaws - what would you do?
    I bought my Tormach used, and part of that used was that someone had run end mills into the moveable vise jaw. It does bug me a bit when I have to look at it, so it made me wonder how fussy people are in general about their machine.
    Would you
    a) Live with it
    b) Stick in a carbide end mill and flatten both jaw tops until the damage was machined out (maybe 20 thou - 25 thou?)
    c) Buy new jaws?
    Just curious.......
    Attachment 275030
    Mar 2012
    51
    Re: Vise jaws - what would you do?
    I would leave it until you are 100% sure you won't run into the jaws yourself. I cut both of my jaws 2 weeks ago while in a hurry. DOH!!
    Dec 2010
    1230
    I haven't had much luck machining them on purpose, but man they cut nice by accident. I'd leave em unless you plan to use as reference (which I never understood). Buy new ones if you are. Or just buyachinable jaws.
    Jun 2008
    1082
    I also hate looking at jaws that I ran a tool into! I usually live with it as long as it's not having too much of a negative impact on how well it clamps.
    If you decide to get new jaws I would suggest checking out monsterjaws.com . They sell American-made 6061 soft jaws for low prices.
    Aug 2009
    610
    Hirudin has the right idea. Grab a couple of pairs of monster jaws and swap them out when you want to run something "special". Otherwise the original jaws can be used for when you want to run a new unproven program or perform some "de-bugging". For the price it is sure hard to beat the monster jaws and you can get various heights and lengths (i.e. full 6" or 2" high).
    Jun 2014
    1774
    little bit of chatter = little bit of pullout = cut vise jaws, I just faced mine off 2 weeks ago, now they have a small nicely machined area about 1/4" on one end!
    I usually live with the small hickeys until I cant stand to look at it anymore.
    mike sr
    Aug 2013
    980
    You can just flycut them down to be equal or better yet, get some Monster jaws as suggested. I use them all the time and if I make a mistake, I am only out $10 for the aluminum ones.
    Quote Originally Posted by widget_maker View Post
    Would you
    a) Live with it
    c) Buy new jaws?
    Just curious.......
    Attachment 275030
    Jan 2013
    97
    Quote Originally Posted by CadRhino View Post
    And if you make a mistake it could be much easier on the machine and the tool.
    Is there any reason, other than durability, not to just use aluminum jaws?
    Jun 2008
    1082
    Yeah! When I hit the jaws I'm glad that they're aluminum instead of steel.
    One consideration is that the aluminum jaws might cause some galvanic corrosion with the cast iron vise. For me it has been a bit of a problem, but not much. I've decided I'm just going to live with it (I guess the fact that it stays hidden is good enough for me) but it might be a bigger problem in other climates or something.
    Mar 2009
    1863
    The first thing I did when I got my machine was to take the steel jaws out of the vise and replace them with aluminum. Now if I nick a jaw, it doesn't kill the cutter.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    I use aluminum soft jaws 99% of the time, always have a few new sets in the drawer. I usually cut steps in them so no need for parallels.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
    Nov 2009
    4415
    Too bad they arent made to just flip over.
    A lazy man does it twice.
    Jan 2015
    50
    I would just live with it as long as you can, we have two vices, one has nicked jaws and the other is perfect, we interchange them and it's kind of like having a "Rough" vice and a "Precision" vice. anytime the program is untested or the cut is just a few thou above the jaw surface or when running it manually i like to throw in the rough jaw because it's already dinged so i won't feel so bad if i nick it again
    Jul 2011
    297
    they add "character"
    or so I have been told...
    Aug 2009
    610
    Quote Originally Posted by SomeWhatLost View Post
    Oh yeah! Maybe the OP should just make up some cool looking geometric pattern that is about the same depth and try to tell folks that they were customized for a "secret" part that he is bound by confidentiality agreements not to discuss. It's kind of like folks that get tattoo cover-ups when they have their significant others name emboldened on their skin. Yeah add some more roses and flames!
  1. Pin vise jaws
    By mountaindew in forum Tormach Personal CNC Mill
    Last Post: 06-23-2014, 09:19 PM
  2. VISE JAWS
    By vegas705 in forum Polls
    Last Post: 11-17-2009, 03:46 PM
  3. vise jaws for parts with kerf?
    By bink in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-03-2008, 01:45 AM
