I have tried a lot of cross measuring tools before the appearance of pro red cross laser alignment. But this 635nm red laser diode tech applied alignment laser tool is just the most accurate and precise cross projecting tool available on the market. This laser alignment tool utilizes import 90 degrees glass coated cylindrical lens as its laser beam emitting source. It is always project the most accurate two perpendicular lines in any working surfaces efficiently.
This red cross laser alignment is projecting at least 3 times brighter red laser beam than 650nm red laser. It is much applicable for longer working distance and high brightness cross generating working environments. Usually it can mounted on machine or devices so as to make much easy and convenient cross positioning in use.
When users are operating high powered red laser alignment, users should always pay special attention to powerful laser radiations. Usually users should try to prepare a pair of laser safety goggles so as to assure safe and accurate cross generation in all working places.
