587,675 active members*
3,935 visitors online*
Results 1 to 3 of 3
    Nov 2013
    22
    Agie Wire cut (150 HSS) Tension adjustment
    I have a problem with Agie wire cut machine.
    The problem is wire broken when start cutting condition.
    Please let me know how to adjustment tension of wire or other solution for solve it.
    Thank you.
    Kittiwat
    Oct 2014
    11
    Re: Agie Wire cut (150 HSS) Tension adjustment
    FW ( will adjust wire tension) is more then likely set to high tension , would try setting CW= 2 ( CW wire type) and FW= 10 at to start out
    Oct 2005
    859
    Normally it is just a lower power setting for entry and exit not tension change.
  1. Agie Dem 315 wire edm
    By s00073055 in forum EDM Discussion General Topics
    Last Post: 01-31-2013, 10:26 PM
  2. AGIE WIRE EDM
    By mescotc in forum EDM Discussion General Topics
    Last Post: 04-15-2012, 07:12 PM
  3. Steel wire in tension
    By greybeard in forum Metallurgy
    Last Post: 01-02-2012, 09:48 PM
  4. AGIE 100 wire
    By wtm5863743 in forum EDM Discussion General Topics
    Last Post: 09-07-2010, 01:20 PM
  5. Wire tension
    By gguidi in forum CNC Wire Foam Cutter Machines
    Last Post: 10-20-2006, 03:40 PM
