587,192 active members*
2,320 visitors online*
Results 1 to 7 of 7
    where's all my coolant going?
    like the title says, where's all my coolant going? I don't have any leaks but yet I'm losing at least 1-2 gallons a day. my machine is only running on an average of 5 hours a day and half the time I'm cutting delrin so I'm not even using coolant, just air
    Only logical thing I can think of is that the delrin chips are absorbing the coolant, but I wouldn't think it would absorb that much but maybe I'm wrong.
    Any ideas?
    Dec 2010
    1230
    Quote Originally Posted by Concepts_Design View Post
    Any ideas?
    1-2 gallons for 2.5 hours of running isn't crazy. Evaporation, coolant carried off by parts and chips is where most of it goes. For reference I go through 10-15 gallons a day on my HAAS and 5-10 gallons on the Tormach when I was doing production on it.
    Re: where's all my coolant going?
    wow, I really never would have thought it would be that much. I guess i'll have to keep more water on hand so I don't keep having to run into the house to get some
    thanks for the quick response
    Aug 2009
    610
    Yes you will lose coolant and need to keep an eye on it to top it off as needed. When I was located in CO the flood coolant loss was nuts! I kept a couple of gallons of water on the ready at all times. The evaporation factor was unreal out there. Be prepared to add water quickly then check your concentration to make sure that you don't need to add more coolant to the sump as well. Also UHMW and Delrin do hold a lot of coolant. Those crazy strings and fliers that are created when machining the plastics creates a lot of surface area for the coolant to lie upon. Fun, fun, fun! I guess one good thing about a total loss system (i.e. FogBuster) is that you can really plan on when to add the coolant.
    Jun 2014
    1780
    One thing that I found that helps a lot is to contain the coolant to the table, I use a 4 sided shield and drains from the table directly to the screen, keeping it off the machine base. The idea is to cut down the surface area which equates to less evaporation.......
    mike sr
    Aug 2013
    980
    It is amazing.
    It will help if you clean up your chips after each run.
    Feb 2010
    371
    I use two rectangular cat litter containers. One is about half the height of the other and stacks nicely into the taller one. The short one has holes drill in the bottom. Excess coolant will drain into the bottom bucket. As I need to top off the coolant, I'll pour a bucket of water through the chips, using the drainage for top off.
  1. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  2. Air coolant?
    By tbaker2500 in forum Tormach Personal CNC Mill
    Last Post: 09-08-2013, 02:05 AM
  3. Coolant Tip
    By ntcnc in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2010, 01:31 PM
  4. Pin For Coolant?
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 03-17-2008, 01:24 AM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
