I am trying to cut a CBORE as shown below with the following code.
The rhinocam simulation shows it cut correctly, however when the code is loaded into Mach3, I don't see the same tool path and the cut is incorrect. The only way around this was to change the arc output setting in Rhinocam and output as lines. However if I am not mistaken, Mach 3 does interpret G2 and G3 codes doesn't it?
Code:G00 G49 G40.1 G17 G80 G50 G90 G20 (Hole Pocketing_CBORE 0.3) M6 T3 M03 S13500 G00 Z1.5000 X-5.1574 Y0.6252 G01 Z0.0250 F60.0 G17 G02X-5.1573Y0.6250Z-0.1500I-0.0952J-0.0002 F190.0 X-5.4578I-0.2051J0.0000 X-5.0475I0.2052J0.0000 G01 X-5.1573 X-5.1574 Y0.6252 G02X-5.1573Y0.6250Z-0.3000I-0.0952J-0.0002 X-5.4578I-0.2051J0.0000 X-5.0475I0.2052J0.0000 G01 X-5.2526 G00 Z1.5000 M5 M9 M30
Mach 3.
The cut piece resembles the Mach 3 path.
