588,465 active members*
5,899 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > PM-45 CNC Conversion (RF45)
Page 44 of 44 34424344
Results 861 to 874 of 874
  1. #861
    Feb 2011
    605
    Re: PM-45 CNC Conversion (RF45)
    Yeah i lowered the screw. It needed it to have proper clearance and a sturdy design of the ballnut mount. I also changed the position of the x screw to be lower.
    Honestly looking at my pictures are your best bet. You should be measuring and designing based on your machine. These RF45s are all different. I had to do things that others didnt.
  2. #862
    Feb 2011
    605
    Well this thread is pretty much wrapped up meow.
    PM-45 CNC conversion built/run/sold.
  3. #863
    Jan 2012
    139
    Brand new? Very nice.
    www.benchtopprecision.com
    | BF20/G0704 Belt Drive Kits | X2 Mini-Mill Belt Drive Kits |
  4. #864
    Feb 2011
    605
    Yes, new.
  5. #865
    Aug 2014
    28
    Congrats on the new machine. If The Lord is willing, I will hopefully start a rf45 conversion next year. Your thread will be one of the few I have read through the last couple years for this conversion. BTW I guess the EVO and the wife park outside? That new machine is a beast!!
  6. #866
    Feb 2010
    3447
    Gorgeous machine!!! If I need something made in the future well have to talk since your local.
  7. #867
    Jan 2011
    11
    omg. you're the best.
  8. #868
    Jan 2008
    25
    very cool upgrade!
    congrats!
  9. #869
    Apr 2009
    98
    Quote Originally Posted by jid2 View Post
    Chip tray is almost done. Just need to rivet and weld in the corner pieces and then silicon the seams. Then cut the access hole in the bottom. The gap in the front center is the removable front face which also needs to be riveted and welded together but I'll do that later.
    Temporary storage until the mill is put on the new stand.
    Is this stainless or aluminum?
    What gauge?
    Thanks,
    -Martin
  10. #870
    Feb 2011
    605
    ^^^^^^ Aluminum is .032" thick.
    Just a little bump for those interested in the difference in cycle time of a proper machining center versus a hobby grade machine I have video of doing the same operation on my old RF45 CNC and the Speedio.
    Total cycle time includes putting the knob in the vise and setting the Z height. On the RF45 I used a gauge block, on the Speedio it's probed.
    Total Cycle time RF45 CNC: 3:30 seconds.
    Total Cycle time Speedio: 53 seconds
    Raw machining time removes the setup and it's just the cutting:
    Raw time RF45: 2:45 seconds.
    Raw time Speedio: 27 seconds.
    Total time the Speedio is 4X faster.
    Raw time the Speedio is 6.11X faster.
  11. #871
    Aug 2010
    278
    https://www.youtube.com/watch?v=bbnNvYYzGSs
    https://www.youtube.com/watch?v=iakGRvescaw
    How much with new machine, may i ask?
    Hive 8 - G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver
  12. #872
    Feb 2010
    3447
    That's crazy fast!
  13. #873
    Mar 2017
    98
    Hi jid2, I just started reading your thread, so apologies if these were answered. Did you RF-45 end up being able to hold 0.001? or better? Did you use C5 ballscrews?
    Where I come from anything better than C5 seems to get exponentially more expensive. From my little reading these might be required for the accuracy I'm after.
    I am basically wondering if I throw money at my RF-45 can I get an accurate CNC machine (albeit not as fast as a proper VMC)
    Thanks, and nice machines.
  14. #874
    Feb 2022
    5
    Making some strategic improvements to organization and garage awesomeness. New tool box for holding machine related tools, with Lista organization inserts for drills, taps, and endmills.
    Spent the weekend cleaning the garage cement and then epoxy coating.
    I agree with Lista's organization.
  1. Starting another DMM conversion, IH RF45 clone
    By ayorba in forum Dmm Technology
    Last Post: 06-08-2014, 02:36 AM
  2. HM45 Conversion (Yes another RF45 clone)
    By slipery in forum Benchtop Machines
    Last Post: 12-19-2011, 12:07 AM
  3. Am I Looking for NOISE trouble (RF45 Conversion)
    By Bird_E in forum CNC Machine Related Electronics
    Last Post: 03-30-2011, 07:37 PM
  4. AC Servo on RF45 Conversion help
    By Maglin in forum Servo Motors / Drives
    Last Post: 02-23-2011, 03:57 PM
  5. RF45 clone CNC conversion
    By GMitchell in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2009, 05:50 AM
