Re: Brand New Haas VF3 and Pricing
Originally Posted by
GITRDUN
Heres a usable Bobcad post script for Haas Mills i modified. It gets rid of all the junk codes not needed in the Haas program and is safe to simply post and use, at least for me. On all drill cycles i modified it to output only a G73 canned cycle using Q K R F. If you dont want to peck just change that line in your program or whatever works for you. Also it will output the Predator simulation codes in the program header so all you need to do is run the post processor from BC, open it up in Predator, then push the backplot tab in Predator and watch it run the simulation if you want to verify it.
I had to add a .txt extension to the name of the file to get CNC Z to upload it. So you might have to remove that for Bobcad to recognize it, dont know. Just download it into the folder where the rest of your BC post scripts are stored.
I had a BobCad program open and thought I would try your post. It locked up Predator when I tried to run it, every time. Had to use task manager to close the Predator. Maybe a little to many things removed?
Also it added diameter offsets for the tools?
(MTOOL T1 S4 D.116 C0. A118. H5. DIAM_OFFSET1 =.058)
(MTOOL T4 S1 D.078 C0. A0. H5. DIAM_OFFSET4 =.039)
I'm back to my slightly modified post.
Mike
Maybe because I'm running V-23?
M
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
