Re: BURNED OUT PIN on z axis driver
Assuming that only the pin is damaged and not the driver itself, you could give it a little gentle file to remove the burrs, it still looks long enough to mate with the socket. Failing that, you could always cut the socket and carefully solder the wire back onto the pin. Lastly, you could replace the connector. If the driver is damaged, it would need repaired, at which point the connector would be replaced anyway. It really depends on how good your soldering skills are
When it all goes wrong, own up and tell the boss it was someone else!
