Ok I am going out of my mind.
I need to cut some pc's for a RC plan kit.
I have them CAD in DXF and the run them in Mach 2 to convert to gcode.
Oh and between DXF and Mach 2 I converted to plotter in Corel.
When I convert the DXF to gcode I get like 50 or more tooth paths.
I ran the Sim and got 18 mins to cut a pcs that would take maybe 3 mins with a jig saw.
There are just to many tool paths. The pc is egg shaped with the center cut out. But the tool path runs a 1 inch cut then picks up goes to the top of the pc does the same then runs some where else all star shapped. I need it to drop once run the full inner circle, pick up and drop and route the out circle.
I need help![]()
BTW I used corel draw to group the layers cause I thought the tooth path was picking up each line from each layer, I soon found out it did me no good.![]()
