Still a joke !!!
The more you use power the less time your tube will live !
I cut 5 mm plywood at 8mm/s and 48% of power
3 mm plywood at 22 % power and 13mm/s
When I look at your numbers it seems that your laser engravers are not really efficient , my friend use a 80w laser tube and cut at 24mm/s a 5 mm plywood at 41% of power and 5 mm MDFat 50% of power and 11mm/s.
So my conclusion: or my friend is a fantastic engineer that knows really well laser and who is able to do fantastic adjustements to obtain that(I don't think so) or your engineers doen't know enough(or doesn't want) to make real efficient laser engravers(I won't lie to you it's my opinion).
To tell someone that it needs a 80w to cut 3mm plywood is a lie that's all, you can see a lot of videos from users all around the web that proove that 40w laser can cut 3mm plywood. I understand that you are here for commercial, but it isn't a reason to give wrong informations to new users !!!
Sincerely yours
PS: and what about that machine, it's supposed to be a laser cuting machine with 40w laser tube....................one of your products !!!!!!!!!!!!!!!!
![](http://www.cnczone.com/forums/attachment.php?attachmentid=282274&stc=1)
Ho !! what do we have here ? .....As I can read .....it supposed to cut wood !
AccTek AKJ6040 mini laser engraver - laser engraving cutting machine_Jinan Acctek Machinery - Jinan AccTek Machinery Co., Ltd
