587,119 active members*
3,733 visitors online*
Page 1 of 6 123
Results 1 to 20 of 108
    Mar 2014
    1131
    My 2nd 3 axis CNC Router build
    Hi all,
    I'll add some details later. Here are some images.
    Please feel free to ask if you have some questions.
    Best
    First stock is ready to cut.
    And the first parts are ready.
    Mar 2014
    1131
    Re: My 2nd 3 axis CNC Router build
    OK here are some details:
    - The outer extrusions of the base are 40x80mm heavy type aluminum. The extrusions inside the base are 40x80mm light type but same.
    - The front and rear walls of the base are 12mm thick 6061 aluminum.
    - Profiles on the Y are 40x120mm aluminum extrusion. One is placed vertical and other is horizontal.
    - I'll take apart my current router to use the electronics and linear stuff which are:
    - 4 x Nema23 motors (I'd like to replace them with servos in the future)
    - 15mm linear rail and blocks on X and Y axis
    - 12mm THK linear rail and blocks on the Z
    - I'll keep using my homemade control box (pic attached).
    Mar 2014
    1131
    Just purchased M10 and M6 helical taps from the LHS. I also get a carbide M10 drill bit for machine. This one is much shorter and precise.
    Mar 2014
    1131
    Forgot to mention. This is a 600x550mm machine.
    Mar 2014
    1131
    Little more progress.
    Mar 2014
    1131
    Unfinished Z and Y axis.
    Feb 2004
    304
    Looks Great!
    Mar 2014
    1131
    Thanks Kev.
    Feb 2004
    304
    Nice renderings also. What program did you model it in?
    Mar 2014
    1131
    Solidworks 2014
    Sent from my GT-I9300 using Tapatalk 2
    Mar 2014
    1131
    Just a little update. One of the plates was slightly bent. Had to make some pitbull jaws (I think they call it so) to fix the plate to the machine. Ran a faceing operation.
    [MEDIA=youtube]QOy-oKqjVfE[/MEDIA]
    Mar 2014
    1131
    Mar 2014
    1131
    Mar 2014
    1131
    462 views and only one comment. I think I should stop posting the process.
    Jun 2009
    122
    Looking good. Dont stop posting, your efforts are appreciated.
    How did you bore the large holes in the plates? Surface finish looks excellent..
    Mar 2014
    1131
    The holes are 4, 5, 6 and 10mm diameter. I used drill bits for them. As for the surfaces, I haven't run a finish operation. Just roughing. I think the carbide 6mm 2 flutes end mill did a good job.
    I'm glad you like it. Thanks.
    Mar 2014
    1131
    The bridge is coming out.
    Jun 2015
    17
    Azalin,
    Beautiful Build! I'm using solidworks 2015 and have the same issue going on! No responses! Just so you know I really appreciate your time posting, it is really helping me in my design.
    In your gantry it looks like you are using 10series 80/20 2x4 (or 15 series), how did you cut your extrusions? used a chop saw? or band saw?
    What is the length across the gantry?
    Mar 2014
    1131
    They have a nice machine in the shop that I purchased the extrusions. A machine with DRO. It allows them to cut the profiles very precise.
    The profiles in the gantry are 10 series 40x120.
    Total length of the gantry is 800mm. Length of the Y axis is 800 too.
    Thanks.
    Mar 2014
    1131
    The next is to cut the step motor and BK12 mount.
Page 1 of 6 123
  1. 5 axis 3D router build
    By Hommersimpson in forum Uncategorised WoodWorking Machines
    Last Post: 02-28-2013, 08:55 PM
  2. Build log - 5 axis router
    By jsheerin in forum DIY CNC Router Table Machines
    Last Post: 02-01-2011, 07:17 AM
  3. My First 3 Axis CNC Router Build
    By hammajamma in forum DIY CNC Router Table Machines
    Last Post: 03-02-2008, 02:05 AM
  4. Help Want To Build A 4 Axis Router 60*144*22
    By CETICARS in forum DIY CNC Router Table Machines
    Last Post: 01-30-2006, 09:03 PM
  5. Help Want To Build A 4 Axis Router 60*144*22
    By CETICARS in forum Open Source CNC Machine Designs
    Last Post: 01-24-2006, 03:47 AM
