587,202 active members*
2,957 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam over 50,000 RPM?
Results 1 to 6 of 6
    Jul 2015
    21
    Hello, the default machine definition in Mastercam only allows for a maximum of 50,000 RPM for the spindle speed. Is there a way for me to run it at 60,000 RPM? Where can I acquire a machine definition that would allow me to do this?
    Thank you.
    May 2012
    180
    Re: Mastercam over 50,000 RPM?
    You should be able to change this inside the machine def.
    Jul 2015
    21
    Quote Originally Posted by Bm150 View Post
    I'm not quite sure how. I tried googling it but couldn't really find much.
    May 2012
    180
    I'll do some screen shots. Brb
    May 2012
    180
    Ok, start by selecting this from the menu, Mastercam version shouldn't matter
    Attachment 287468
    Then click open
    Attachment 287470
    Select your machine from the list
    Attachment 287472
    Once open double tap on the spindle
    Attachment 287474
    Change this value to what you need .
    Once done save as you exit and should be fine.
    When working with already saved mastercam files you may need to reload the machine.
    This is done via files on the OPs Toolbar.
    Jul 2015
    21
    Wow, thank you so much! That worked flawlessly. Thanks once again.
  1. MASTERCAM OR NOT TO MASTERCAM. THAT IS THE QUESTION.
    By Jonathan E. in forum Mastercam
    Last Post: 03-06-2016, 08:33 PM
  2. Replies: 4
    Last Post: 07-03-2014, 05:45 PM
  3. Converting Mastercam Files without Mastercam.
    By OutlawMachine in forum Uncategorised CAD Discussion
    Last Post: 04-16-2014, 11:38 PM
  4. Replies: 1
    Last Post: 03-17-2014, 08:49 AM
  5. nesting mastercam x or mastercam x3
    By zewanil in forum Mastercam
    Last Post: 05-21-2009, 07:30 PM
