588,268 active members*
12,239 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > open source Atmel/arduino PID motor control
Page 11 of 13 910111213
Results 201 to 220 of 250
  1. #201
    Mar 2009
    533
    Sorry about the false alarm of mine. It does fit. I also checked it with my calipers this morning.
    Last night I somehow didn't get the board oriented right and just eye-balling it made me think it was off.
    I should have gone to bed and not quickly try things late at night and scare AnonCh4rl1 like that.
  2. #202
    Aug 2013
    14
    Quote Originally Posted by KOC62 View Post
    Are you Making a board from the files I've posted then? That's brave! very brave.
    I removed the ground payne from the design, I do not fully understand what I'm doing in eagle so I dont know how that will affect things.
    I noticed with the files I posted above the Tracks do not seem much bigger at all, I increased them yet again before printing them and taking them to be photocopied, I will update the above files shortly.
  3. #203
    Mar 2009
    533
    No, I'm not ready to build a board.
  4. #204
    Aug 2013
    14
    Attachment 203934
    Attachment 203936
    Attachment 203938
    Attachment 203940
    This is the new board, realised the screw terminals I added in Eagle have smaller spacing but was able to modify with some nail varnish before etching.
    I am still awaiting my new Arduino, I just wired up this board and it gives 240v output even when I remove the jumper from the pins for the power switch, obviously theres the Capacitor and resistor across both lives But with only a multimeter I have no idea how I would test if the triac is toast and passing current. I will have to wait for my arduino and wire it up to my lathe motor and see what the deal it.
  5. #205
    Oct 2013
    6
    When I printed the eagle board it didn't fit on my Arduino Uno. Does Eagle not print actual size?
  6. #206
    Aug 2013
    14
    Just an update, I have my new Arduino and I got the board flashing a 220v lead light, I found that the BT139 I had was toast, it was just letting current like 0.03 ohms or something between power terminals with nothing going to the gate. I put in the BTA41 - 40amp beast and the light also stayed on, I was confused and thought there was a short, but I uploaded the basic arduino blink example on pin 5 and sure enough that Lead light flashed, so I will have to go over pin assignments and code 2moz. I just re-read this and noticed mention that the thing wont work without an rpm sensor, The board has some strange features now i come to play with it, The switch seems to only turn off the indicator LED and maybe the zero crossing signal, surely a better idea would be to switch the feed to the MOC Optocoupler or power to the whole arduino directly, I would not rely on that as your only switch on any kind of industrial machine, if there's a fault on the board the MOC and Triac can still fire.
  7. #207
    Jul 2010
    8
    Re: open source Atmel/arduino PID motor control
    How is work? Look good.
    Sent from my LT18i using Tapatalk
  8. #208
    Sep 2014
    Can you give me some information about RPM sensor? Your link you give here is inaccessible. Thanks!
  9. #209
    Sep 2013
    6
    Hi friends I want to do this project. But could not figure out how you can help the CON11 connentor work?
  10. #210
    Mar 2009
    533
    Quote Originally Posted by recep89 View Post
    You need to provide, say a 3V to 5V positive going pulse to con11.pins 1 & 2 This pulse will trigger the triac to turn it ON.
  11. #211
    Sep 2013
    6
    Does the need to give 5V connector CON11 ?
    GT-I9300 cihazımdan Tapatalk kullanılarak gönderildi
  12. #212
    Mar 2009
    533
    For example, if you use an Arduino, it will provide the pulse to CON11. You don't apply 5V to the CON11.
  13. #213
    Sep 2013
    6
    I got it , thank you for the information you gave on
  14. #214
    Jun 2014
    4
    excuse my ignorance...in the end what should be connected to CON 11 ? and the sensor is connected to the J - HLS - 1 ?
  15. #215
    Mar 2009
    533
    Quote Originally Posted by acilin1 View Post
    CON 11:
    Needs a pulse to fire the triac. This pulse comes from the Arduino controller.
    J-HLS-1:
    Needs a pulse from the sensor to indicate that the motor rotated 360 degrees. 1 pulse for every motor shaft revolution.
  16. #216
    Jun 2014
    4
    excuse me but do not understand...That means do not connect anything to con 11 connections are already on the pcb? must put a switch? ...
  17. #217
    Mar 2009
    533
    No.
    Connectors are used to connect something from another device. In this case, it means that your speed sensor connects to J-HLS-1 so that the Arduino can calculate at what RPM the motor is turning.
  18. #218
    Jun 2014
    4
    yes to con j-hls-1 i connecting the rpm sensor but to con 11 What should I connect?
  19. #219
    Mar 2009
    533
    I didn't look at the pcb. Taking another look at the schematic it looks he uses D5 port from the Arduino to provide the trigger for the triac.
    If this connection is already on the pcb then you don't need to connect anything to this connector. It would be a method to connect an other trigger source than the Arduino.
    I never finished building this project, and I don't have a pcb either.
    Sorry if I confused you with my previous comments. I didn't notice the D5 line before, which I assume is on the pcb.
  20. #220
    Jun 2014
    4
    someone can tell me what voltage have the capacitors in the original scheme?
  1. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  2. Arduino PID Motor speed control for router
    By EL34 in forum CNC Machine Related Electronics
    Last Post: 12-02-2012, 11:34 PM
  3. Open Source Spindle Control
    By rcpilot82 in forum Open Source Controller Boards
    Last Post: 05-27-2011, 10:25 PM
  4. EMC2 (Open Source) Plasma Control w. THC
    By rugludallur in forum Waterjet General Topics
    Last Post: 07-19-2006, 09:25 PM
  5. Any open source or cheap driver for bipolar motor 6 Amp, 2.7V??
    By berryCR in forum Stepper Motors / Drives
    Last Post: 06-10-2006, 05:43 AM
