Originally Posted by
ger21
Accordingto what I've read at SDP-SI, GT2's are the best choice, with the least backlash.
Ok, so GT2 belts it is.
Going with the 3mm GT system (largest in the list, no GT2 listed) - I get this:
I changed the Belt Grooves to get the Actual center distance as close as possible to my Desired - I'm guessing this is why you can change that value!
I also see now that you can change the Pulley Grooves to maintain the ratio you desire...
ger21
You want to take the speed you want to move at, and take the top rpm of your servos, and gear accordingly, so that your servos are spinning at close to their max rpm when your machine is making rapid moves. There is no general rule, like use 2:1.
Ok, so on the servo spec-sheet it says that the rated speed is 2150rpm. But, on the chart/graph - well I honestly can't figure out what speed is ideal. Looks to me like around 700rpm? But, if I am reading the chart right - 700rpm would be 85oz/in? That seems really really low...
ger21
Also, I see about 6-1/2 turns per inch. Maybe a 4mm pitch? You can fine tune it with the software once evreything is up and running.
On the X and Y Ballscrews, right? Yes, they are 4mm pitch. I'm not sure of the pitch on the Z-Axis ballscrew.
But, you saying I can work all that out in software - just gear them all the same (same pulley-pitch, belts, etc)?
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
