588,663 active members*
4,695 visitors online*
Results 1 to 13 of 13
    Jan 2011
    57
    cnc laser designs
    can anyone tell me if their are open source designs for building a cnc laser cutter. many thanks
    Nov 2008
    644
    Re: cnc laser designs
    Open builds.org has some content. Unless your ok with ordering components from China, start with a domestic supplier. They may also have designs
    Apr 2004
    326
    Nov 2010
    786
    Quote Originally Posted by Kosh View Post
    Lasersaur is a child`s toy.
    Never build cnc machines with alu profiles.
    CNC lasers, constructions, service
    Jan 2011
    57
    thanks for your help. im going to build a 130w laser with a working area of about 1000mm x 1000mm
    any ideas are more than welcome.
    Nov 2008
    644
    There are no open source designs for a machine that large. I'd price out the components at lightobject.com vs a complete machine. I doubt that you can build cheaper then buy. Unless you go the 8020 route for the frame you will need access to metal fab machines. Good luck I'd like to hear what you find
    wklaserliu Guest
    Quote Originally Posted by mark.a View Post
    HI mark.a ,
    Build a machine by yourself is a interesrting thing, 1000*1000mm near model like :1200*900, etc.
    during your building, any help can ask freely.
    Quiven form www.wklaser.com
    skype: wkquiven
    [email protected]
    Apr 2004
    326
    Quote Originally Posted by cinematic2 View Post
    Wow, did you really just make that generalization ?
    Seems like there are plenty 8020 machines with very happy owners.
    Nov 2010
    786
    Every newcomer is very happy having laser machine. Till the time he has a contact with real laser machine.
    Once again. Only stupid makes cnc machine with alu profiles.
    Alu mada can be 3D printer. Not laser engraver / cutter.
    Jan 2011
    57
    i have already built a cnc router with a working area of 700mm x 700m. I made a lot of the parts from making templates and casting alluminum.
    i also have a milling machine and lathe so i would actually be making most of the parts myself. i will keep you upto date on the build so far
    the cost of the main electrical parts is around £1100.
    Apr 2004
    326
    OK Shrek, back to the bridge for you!
    Putting you on ignore.
    Nov 2008
    644
    I would like to see a build log in lasers. For some reason folks on this site would rather buy then make a laser cutter. I think there are a higher percentage of people using lasers in a business so they don't want to spend the time or risk downtime.
    In fact building a machine gives you maximum knowledge of how it work and if something stops working you fix it. A machine from China offers little to no support. So going for it and post progress and questions along the way
    Aug 2015
    11
    Hi Cinema,
    Is there any technical, professional argument behind your words, or you are just being extrusion racist.
    Of course there is no problem at all with aluminium extrusion laser engravers/cutters, if they designed correctly.
    Lasersaur is not so well-designed, indeed, but you can make a much better one.
    Regards,
    Tele
    PS: you have a nice vakuum-cleaner, can it sniff the soap-water up ?
  1. Designs
    By magnar81 in forum Uncategorised WoodWorking Machines
    Last Post: 05-04-2014, 04:41 PM
  2. ?? 4 fix gantry designs
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 06-19-2009, 01:19 AM
  3. looking for designs
    By justin22885 in forum Musical Instrument Design and Construction
    Last Post: 02-27-2009, 10:00 PM
  4. Where can I buy plastic designs from?
    By noac in forum Glass, Plastic and Stone
    Last Post: 03-06-2007, 08:30 AM
