Code:
# Post Name : MASTER_FAGOR
# Product : MILL
# Machine Name : MACHINE
# Control Name : FAGOR 8050/8055 M CNC
# Description : IHS MASTER GENERIC MILL G-CODE POST
# Associated Post : NONE
# Mill/Turn : NO
# 4-axis/Axis subs. : YES
# 5-axis : NO
# Subprograms : YES
# Executable : MP v9.05
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Revision log:
# Programmers Note:
# IHS 01/30/02 - Mpmaster based on CNC Software's V8/V9 Mpfan, dat
# IHS 01/30/02 - Initial post update for V9, dat
# IHS 04/01/02 - Comments repeated in translational subs, dat
# IHS 05/01/02 - lock_codes logic tweak, dat
# IHS 05/07/02 - arccheck set to 3, dat
# IHS 05/17/02 - Removed null comment from subs, dat
# IHS 05/24/02 - Rotary subprograms mod, dat
# IHS 07/17/02 - Incremental drilling calculation mod, dat
# IHS 07/25/02 - Switch added to control rotary index move retracts, dat
# XXX MM/DD/02 - Written for Company X from Mpmaster, xxx
# Features:
# This post supports Generic Fagor code output for 3 and 4 axis milling.
# It is designed to support the features of Mastercam Mill V9.
# Following Misc. Integers are used:
# mi2 - Absolute or Incremental positioning at top level
# 0 = absolute
# 1 = incremental
# mi9 - Lock on First WCS - Set in first operation
# 0 = No
# 1 = Yes
# mi10 - M00 before operation
# 0 = No
# 1 = Yes
# Work offsets:
# wcstype - Work coordinate system
# 0 = Reference return is generated and G92 with the
# X, Y and Z home positions at file head.
# 1 = Reference return is generated and G92 with the
# X, Y and Z home positions at each tool.
# 2 = WCS of G54, G55.... based on Mastercam settings.
# 0 thru 5 = The WCS of G54 thru G59 respectively.
# 6 and up = The WCS of G54.1 P1 and up.
# 3 = Off
#Canned text:
# Entering cantext on a contour point from within Mastercam allows the
# following functions to enable/disable.
# Cantext value:
# 1 = Stop = output the "M00" stop code
# 2 = Ostop = output the "M01" optional stop code
# 3 = Bld on = turn on block delete codes in NC lines
# 4 = bLd off = turn off block delete codes in NC lines
# 5 = Dwell = Input G04 K100 command
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative
# axis of rotation).
# vmc = 1 (vertical machine) uses the top toolplane as the base machine
# view.
# vmc = 0 (horizontal machine) uses the front toolplane as the base machine
# view.
# Relative to the machine matrix -
# Rotation zero position is on the Z axis for rotation on X axis.
# Rotation zero position is on the Z axis for rotation on Y axis.
# Rotation zero position is on the X axis for rotation on Z axis.
# The machine view rotated about the selected axis as a "single axis
# rotation" are the only legal views for 4 axis milling. Rotation
# direction around the part is positive in the CCW direction when
# viewed from the plus direction of the rotating axis. Set the variable
# 'rot_ccw_pos' to indicate the signed direction. Always set the work
# origin at the center of rotation.
#Toolplane Positioning:
# Create the Cplane and Tplane as the rotation of the machine view about
# the selected axis of rotation. The toolplane is used to calculate
# the position of the rotary axis. This is the default setting.
#3 Axis Rotary (Polar)
# Polar positioning is offered in Mastercam 3 axis toolpaths through the
# rotary axis options dialog. The selected toolpath is converted to angle
# and radius position. The axis of rotation is forced to zero.
#Axis substitution:
# Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder. The rotary axis button must be active for axis
# substitution information to be output to the NCI file. The radius of
# the rotary diameter is added to all the Z positions at output.
#Simultaneous 4 Axis (11 gcode):
# Full 4 axis toolpaths can be generated from various toolpaths under the
# 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are
# converted to 4 axis paths where only the angle about the rotation axis
# is resolved.
#Drill:
# All drill methods are supported in the post. See Simultaneous 4 Axis.
#Additional Notes:
# 1) Disable 4 axis by setting the numbered question 164. to 'n'.
# 2) G54 calls are generated where the work offset entry of 0 = G54,
# 1 = G55, etc.
# 3) Metric is applied from the NCI met_tool variable.
# 4) Incremental mode calculates motion from home position at toolchanges.
# The home position is used to define the last position of the tool
# for all toolchanges.
# 5) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for
# the 'top level' absolute/incremental program output. Subprograms are
# updated through the Mastercam dialog settings for sub-programs.
# 6) Always avoid machining to the center of rotation with rotary axis!
# 7) Transform subprograms are intended for use with G54.. workshifts.
# General Output Settings
spaces : 1 #Number of spaces to add between fields
omitseq : no #Omit sequence numbers?
seqmax : 9999 #Max. sequence number
arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
breakarcs : 2 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
helix_arc : 1 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
maxrad : 999 #Maximum arc radius
hel_2100 : no #Acramatic 2100 style helical moves, 0=no, 1=yes
usecanned : yes #Use canned drilling cycles? Set to no for long output.
wcstype : 2 #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off
force_wcs : yes #Force WCS output at every toolchange?
stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools
tool_table : 1 #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View
output_z : yes #Output Z Min and Z Max values (yes or no)
cool_zmove : yes #Coolant off with last move
use_pitch : 0 #0 = Use feed for tapping, 1 = Use pitch for tapping
maxfeedpm : 500 #Limit for feed in inch/min
maxfeedpm_m : 10000 #Limit for feed in mm/min
use_gear : 0 #Output gear selection code, 0=no, 1=yes
max_speed : 10000 #Maximum spindle speed
min_speed : 50 #Minimum spindle speed
sextnc .PIM #NC extension override
# Rotary Axis Settings
# Typical Vertical
srotary "A" #Rotary axis prefix
vmc : 1 #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x : 1 #Default Rotary Axis Orientation, See ques. 164.
#0 = Off, 1 = About X, 2 = About Y, 3 = About Z
# Typical Horizontal
#srotary "B" #Rotary axis prefix
#vmc : 0 #0 = Horizontal Machine, 1 = Vertical Mill
#rot_on_x : 2 #Default Rotary Axis Orientation, See ques. 164.
# #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 1 #Axis signed dir, 0 = CW positive, 1 = CCW positive
ret_on_indx : 1 #Machine home retract on rotary index moves, (0 = no, 1 = yes)
index : 0 #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable : 5 #Degrees for each index step with indexing spindle
one_rev : 0 #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)
lock_codes : 0 #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes)
use_frinv : 0 #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
rot_feed : 1 #Use calculated rotary feed values, (0 = no, 1 = yes)
maxfrdeg : 2000 #Limit for feed in deg/min
maxfrinv : 999.99#Limit for feed inverse time
frc_cinit : 1 #Force C axis reset at toolchange
ctol : 225 #Tolerance in deg. before rev flag changes
ixtol : .01 #Tolerance in deg. for index error
frdegstp : 10 #Step limit for rotary feed in deg/min
# Debugging and Factory Set Program Switches
fastmode : yes #Posting speed optimizition
bug1 : 2 #0=No display, 1=Generic list box, 2=Editor
bug2 : 60 #Append postline labels, non-zero is column position?
bug3 : 0 #Append whatline no. to each NC line?
bug4 : 0 #Append NCI line no. to each NC line?
whatno : yes #Do not perform whatline branches? (leave as yes)
# Additional General Output Settings
ldrcode : 0 # Leader character dec. equiv. (fleader outputs code)
ncldr : 20 # No. of leader characters (fleader outputs code)
nobrk : no # Omit breakup of x/y & z rapid moves LEAVE AS NO!!!
omitcrlf : no # Omit CR/LF
#eob : 42 # End of block
nobrk : no #Omit breakup of x, y & z rapid moves
progname : 1 #Use uppercase for program name (sprogname)
sub_level : 1 #Enable automatic subprogram support
sub_seq_typ : 1 #Enable subprogram sequence number reset at sub call
arccheck : 3 #Check for small arcs, convert to linear
atol : .01 #Angularity tolerance for arccheck = 2
ltol : .002 #Length tolerance for arccheck = 1
vtol : .0001 #System tolerance
ltol_m : .05 #Length tolerance for arccheck = 1, metric
vtol_m : .0025 #System tolerance, metric
tooltable : 1 #Read for tool table and pwrtt - use tool_table to disable
m_one : -1 #Define constant
zero : 0 #Define constant
one : 1 #Define constant
two : 2 #Define constant
three : 3 #Define constant
four : 4 #Define constant
five : 5 #Define constant
c9k : 9999 #Define constant
get_1004 : 1 #Find gcode 1004 with getnextop?
rpd_typ_v7 : 0 #Use Version 7 style contour flags/processing?
strtool_v7 : 2 #Use Version 7+ toolname?
tlchng_aft : 2 #Delay call to toolchange until move line
cant_tlchng : 1 #Ignore cantext entry on move with tlchng_aft
newglobal : 1 #Error checking for global variables
getnextop : 1 #Build the next variable table
error_msg : 1 #0=file and prompt, 1=to screen, 2=one to screen
err_file : 1 #0=fatal, 1=all errors, 2=inc mprint, 3=inc prompts, 4=always
# Enable Canned Drill Cycle Switches
usecandrill : yes #Use canned cycle for drill
usecanpeck : yes #Use canned cycle for Peck
usecanchip : yes #Use canned cycle for Chip Break
usecantap : yes #Use canned cycle for Tap
usecanbore1 : yes #Use canned cycle for Bore1
usecanbore2 : yes #Use canned cycle for Bore2
usecanmisc1 : yes #Use canned cycle for Misc1
usecanmisc2 : yes #Use canned cycle for Misc2
# Common User-defined Variable Initializations (not switches!)
xia : 0 #Formated absolute value for X incremental calculations
yia : 0 #Formated absolute value for Y incremental calculations
zia : 0 #Formated absolute value for Z incremental calculations
cia : 0 #Formated absolute value for C incremental calculations
cuttype : 0 #Cut type flag
#0 = Tool Plane, 1 = Axis Subs, 2 = Polar, 3 = 4/5 axis
bld : 0 #Block delete active
result : 0 #Return value for functions
sav_spc : 0 #Save spaces
sav_gcode : 0 #Gcode saved
sav_absinc : 0 #Absolute/Incremental Saved Value
sav_coolant : 0 #Coolant saved
sav_workofs : 0 #Saved work offset
sav_frc_wcs : 0 #Force work offset flag saved
sav_progno : 0 #Saved program number
#sav_n1 : 0 #Saved sequence number
#sav_n2 : 0 #Saved sequence number
sav_rot_on_x : 0 #Rotary configuration saved
toolchng : 1 #On a toolchange flag
spdir2 : 1 #Copy for safe spindle direction calculation
#Drill variables
drlgsel : -1 #Drill Select Initialize
drillref : 0 #Select drill reference
peckacel : 0 #Fractional percent to reduce peck2 when usecan.. : no
drlgcode : 0 #Save Gcode in drill
sav_dgcode : 0 #Drill gcode saved
#Subprogram variables
mr_rt_actv : 0 #Flag to indicate if G51/G68 is active
#0=Off, 1=Toolchange, 2=Subprogram call/start, G68
#3=Absolute start, both
rt_csav : 0 #C saved value
end_sub_mny : 0 #Many tool setting captured at transform sub end
#Rotary/Index variables
prvcabs : 0 #Saved cabs from pe_inc_calc,
#Used for rotary feed and direction calculations
cdelta : 0 #Calculation for angle change
rev : 0 #Calculation for deg/min
sav_rev : 0 #Saved revolution counter
indx_out : c9k #Rotation direction calculation
fmt 16 indx_mc #Rotation direction calculation
#Vector Constants for Rotatary Calculations
aaxisx : 1 #A axis rotation vector constant
aaxisy : 0 #A axis rotation vector constant
aaxisz : 0 #A axis rotation vector constant
baxisx : 0 #B axis rotation vector constant
baxisy : 1 #B axis rotation vector constant
baxisz : 0 #B axis rotation vector constant
caxisx : 0 #C axis rotation vector constant
caxisy : 0 #C axis rotation vector constant
caxisz : 1 #C axis rotation vector constant
#Feedrate calculation variables
frdelta : 0 #Calculation for deg/min
frinv : 0 #Feedrate inverse time
frdeg : 0 #Feedrate deg/min actual
prvfrdeg : 0 #Feedrate deg/min actual
ldelta : 0 #Calculation for deg/min, linear
cldelta : 0 #Calculation for deg/min, linear and rotary
circum : 0 #Calculation for deg/min
ipr_type : 0 #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse
#Misc variables
tcnt : 0 # Count the number of tool changes
toolcount : 1 # Tool counter for logic control
toolcountn : 0 # Next tool counter for logic control
toolcountp : 0 # Previous tool counter for logic control
tooltotal : 0 # Tool tool count
nexttool : 0 # Next actual tool
nexttp : 0 # Next tool plane
prvtp : 0 # Previous tool plane
counter : 0 # Counter
nstrlen : 0 # Length of string
last_op_id : 0 # Previous internal operation id
last_cuttype : 0 # Previous cuttype
stock_typ : 0 # Predator Stock Type
cyl_typ : 0 # Predator Cyl Stock Type
z_min : 99999 # Min Z
z_tmin : 99999 # Overall min Z
z_max : -99999# Max Z
z_tmax : -99999# Overall max Z
tapflg : 0 # Flag for tap cycle
sav_mi9 : 0 # Saved mi9 value
numpeck : 0 # Number of pecks
# FORMULAS - global formulas
toolcountn = toolcount + 1 # Index!
toolcountp = toolcount - 1 # Index!
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (:)
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 8 5 0 5 0l #Integer, force five leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place
fs2 16 1 0 1 0n #Integer, forced output
fs 17 1.4lt #Decimal, absolute, four trailing
#String and string selector definitions for NC output
#Numbered question 164. string to detect Rotary axis y/n
sq164
#Address string definitions
stri "I"
strj "J"
strk "K"
strm "M"
strn "N"
stro "O"
strp "P"
srad "R"
srminus "R-"
sblank
#Cantext string definitions (spaces must be padded here)
sm00 "M00"
sm01 "M01"
scant5 "G04 P1"
strtextno
strcantext
#Transform mirror and rotate codes
strns_mir_on "G51.1" #Programmable mirror image code
strns_mir_off "G50.1" #Programmable mirror image cancel code
strns_rot_on "G68" #Coordinate System Rotation
strns_rot_off "G69" #Coordinate System Rotation Cancel
# Error messages
saxiswarn "WARNING-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') OVERWRITTEN BY OPERATION"
saxisoff "ERROR-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') IS DISABLED"
saxiserror "ERROR-INVALID ROTARY AXIS ASSIGNMENT ('rot_on_x') FOR CURRENT OPERATION"
sindxerror "WARNING-INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')"
stlorgerr "ERROR-TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING"
shomeserror "ERROR-G92 WORK OFFSET ('wcstype') DOES NOT SUPPORT TRANSFORM SUBPROGRAM"
sprgnerror "ERROR-SUBPROGRAM NUMBER MATCHES THE MAIN PROGRAM NUMBER"
# Misc strings
snull "" # Null character string
sdot "." # dot string
stest1 "" # Test string 1
stilde "~" # Tidle string
snocomm "DEFINE TOOL NAMES"
stoper "" # String for tool notes
spostname "" # Post name
snullop "UNDEFINED OPERATION"
slicense "IN-HOUSE SOLUTIONS"
# Parameter Tables
fprmtbl 13 2 # Multisurf Finish
10010 stock # Amount of stock to leave on drive surfs
10227 check # Amount of stock to leave on check surfs
fprmtbl 14 2 # Multisurf Rough
# Buffer 3 - Holds the variable 'tlplnno' for each toolpath segment
rc3 : 1
wc3 : 1
fbuf 3 0 1 0 # Buffer 3
# Buffer 4 - Holds the variable 't' for each toolpath segment
rc4 : 1
wc4 : 1
fbuf 4 0 1 0 # Buffer 4
# Buffer 5 - Min / Max
b5_gcode : 0
b5_zmin : 0
b5_zmax : 0
rc5 : 2
wc5 : 1
size5 : 0
fbuf 5 0 3 0 #Min / Max
# Question format statements
fq 1 stock_typ Predator Stock [0=Box,1=Cylindrical]
fq 2 cyl_typ Cylindrical Stock Axis [1=X,2=Y,3=Z]
# Strings - String labels must start with 's' - they are not pre-assigned
#Select operation note
sop00 "NULL......." # String definition
sop01 "CONTOUR...." # " "
sop02 "CONTOUR...." # " "
sop03 "DRILL/MISC." # " "
sop04 "POCKET....." # " "
sop05 "RULED......" # " "
sop06 "2D-SWEPT..." # " "
sop07 "3D-SWEPT..." # " "
sop08 "REVOLVED..." # " "
sop09 "LOFT......." # " "
sop10 "COONS......" # " "
sop11 "FILLET....." # " "
sop12 "FLOWLINE..." # " "
sop13 "M.FINISH..." # " "
sop14 "M.ROUGH...." # " "
sop15 "POINT......" # " "
sop16 "DRILL5AX..." # " "
sop17 "CURVE5AX..." # " "
sop18 "SWARF5AX..." # " "
sop19 "FACING....." # " "
sop20 "OP20......." # " "
sopnote # Target string
fstrsel sop00 opcode sopnote
sdr00 "DRILL/CBORE" # String definition
sdr01 "PECK DRILL." # " "
sdr02 "CHIP BREAK." # " "
sdr03 "TAP........" # " "
sdr04 "BORE 1....." # " "
sdr05 "BORE 2....." # " "
sdr06 "FINE BORE.." # " "
sdr07 "MISC 2....." # " "
sdr08 "CUST 9....." # " "
sdr09 "CUST 10...." # " "
sdr10 "CUST 11...." # " "
sdr11 "CUST 12...." # " "
sdr12 "CUST 13...." # " "
sdr13 "CUST 14...." # " "
sdr14 "CUST 15...." # " "
sdr15 "CUST 16...." # " "
sdr16 "CUST 17...." # " "
sdr17 "CUST 18...." # " "
sdr18 "CUST 19...." # " "
sdr19 "CUST 20...." # " "
sdrnote # Target string
fstrsel sdr00 nextdc sdrnote
# Select month
smon00 ""
smon01 "JAN"
smon02 "FEB"
smon03 "MAR"
smon04 "APR"
smon05 "MAY"
smon06 "JUN"
smon07 "JUL"
smon08 "AUG"
smon09 "SEP"
smon10 "OCT"
smon11 "NOV"
smon12 "DEC"
smonth
fstrsel smon00 month smonth
# General G and M Code String select tables
# Motion G code selection
sg00 G00 #Rapid
sg01 G01 #Linear feed
sg02 G02 #Circular interpolation CW
sg03 G03 #Circular interpolation CCW
sg04 G04 #Dwell
sgcode #Target for string
fstrsel sg00 gcode sgcode
# Select work plane G code
sg17 G17 #XY plane code
sg19 G19 #YZ plane code
sg18 G18 #XZ plane code
sgplane #Target string
fstrsel sg17 plane sgplane
#Select english/metric code
sg20 G70 #Inch code
sg21 G71 #Metric code
smetric #Target string
fstrsel sg20 met_tool smetric
# Cutter compensation G code selection
scc0 G40 #Cancel cutter compensation
scc1 G41 #Cutter compensation left
scc2 G42 #Cutter compensation right
sccomp #Target for string
fstrsel scc0 cc_pos sccomp
# Canned drill cycle string select
sg81 G81 #drill - no dwell
sg81d G82 #drill - with dwell
sg83 G83 #peck drill - no dwell
sg83d G83 #peck drill - with dwell
sg73 G69 #chip break - no dwell
sg73d G69 #chip break - with dwell
sg84 G84 #tap - right hand
sg84d G84 #tap - left hand
sg85 G89 #bore #1 - no dwell
sg85d G89 #bore #1 - with dwell
sg86 G86 #bore #2 - no dwell
sg86d G86 #bore #2 - with dwell
sgm1 G85 #misc #1 - no dwell
sgm1d G85 #misc #1 - with dwell
sgm2 G81 #misc #2 - no dwell
sgm2d G82 #misc #2 - with dwell
sgc9 G81 #custom #9 - no dwell
sgc9d G82 #custom #9 - with dwell
sgdrill #Target for string
fstrsel sg81 drlgsel sgdrill
# Select incremental or absolute G code
sg90 G90 #Absolute code
sg91 G91 #Incremental code
sgabsinc #Target string
fstrsel sg90 absinc sgabsinc
# Feed mode G code selection
sg94 G94 #UPM
sg94d G94 #DPM, See pfcalc_deg if you use another gcode
sg93 G93 #Inverse
sgfeed #Target for string
fstrsel sg94 ipr_type sgfeed
#Canned drill cycle reference height
sg98 G98 #Reference at initht
sg99 G99 #Reference at refht
sgdrlref #Target for string
fstrsel sg98 drillref sgdrlref # Drill cycle G string select
# Generate string for spindle
sm04 M04 #Spindle reverse
sm05 M05 #Spindle off
sm03 M03 #Spindle forward
spindle #Target for string
fstrsel sm04 spdir2 spindle
# Coolant M code selection
sm09 M09 #Coolant Off (Use sm09_0 through sm09_2)
sm08 M08 #Coolant Flood
sm08_1 M07 #Coolant Mist
sm08_2 M08 #Coolant Tool
sm09_0 M09 #Coolant Flood Off
sm09_1 M09 #Coolant Mist Off
sm09_2 M09 #Coolant Tool Off
scoolant #Target for string
fstrsel sm09 coolant scoolant
# Table unlock and lock codes
slock M10 #Axis lock
sunlock M11 #Axis unlock
# Table rotation direction
# Table rotation direction, index
sindx_cw M22 #Rotate CW code
sindx_ccw M21 #Rotate CCW code
sindx_mc #Target for string
fstrsel sindx_cw indx_mc sindx_mc
# Define the gear selection code
flktbl 1 3 #Lookup table definition - table no. - no. entries
40 0 #Low gear range
41 400 #Med gear range
42 2250 #Hi gear range
# Toolchange / NC output Variable Formats
fmt T 4 t #Tool No
fmt T 4 first_tool #First Tool Used
fmt T 4 next_tool #Next Tool Used
fmt D 4 tloffno #Diameter Offset No
fmt D 4 tlngno #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt N 4 n #Sequence number
fmt X 2 xabs #X position output
fmt Y 2 yabs #Y position output
fmt Z 2 zabs #Z position output
fmt X 3 xinc #X position output
fmt Y 3 yinc #Y position output
fmt Z 3 zinc #Z position output
fmt A 11 cabs #C axis position
fmt A 14 cinc #C axis position
fmt A 4 indx_out #Index position
fmt R 14 rt_cinc #C axis position, G68
fmt I 3 i #Arc center description in X
fmt J 3 j #Arc center description in Y
fmt K 3 k #Arc center description in Z
fmt K 2 lead #Helical lead
fmt R 2 arcrad #Arc Radius
fmt F 15 feed #Feedrate
fmt K 4 dwell #Dwell
fmt K 4 dwell_out #Dwell
fmt M 5 cantext #Canned text
#Move comment (pound) to output colon with program numbers
fmt 8 progno #Program number
fmt 4 main_prg_no #Program number
fmt 4 sub_prg_no #Program number
fmt 4 sub_prg_call#Program number
fmt X 2 sub_trnsx #Rotation point
fmt Y 2 sub_trnsy #Rotation point
fmt Z 2 sub_trnsz #Rotation point
fmt I 2 peck1 #First peck increment (positive)
fmt R 2 peck2 #Second or last peck (positive)
fmt C 2 peckclr #Safety distance
fmt H 2 retr #Retract height
fmt J 4 shftdrl #Fine bore tool shift
fmt Z 2 zdrl #Depth of drill point
fmt Z 2 tosz #Drilling top of stock
fmt N 4 n_tap_thds #Number of threads per inch (tpi)
fmt F 2 pitch #Tap pitch (inches per thread)
fmt Z 2 refht_a #Reference height
fmt Z 2 refht_i #Reference height
fmt J 4 numpeckint #Number of pecks
fmt B 2 bval #Peck value
fmt D 2 dval #Refht to zdrl
fmt "TOOL - " 4 tnote # Note format
fmt " DIA. OFF. - " 4 toffnote # Note format
fmt " LEN. - " 4 tlngnote # Note format
fmt " DIA. - " 1 tldianote # Note format
fmt D 17 tldia # Note format
fmt R 17 tcr # Note format
fmt D 2 tldia_pred # Predator VCNC format
fmt C 2 tcr_pred # Predator VCNC format
fmt D 2 tldia_meta # MetaCut View format
fmt R 2 tcr_meta # MetaCut View format
fmt F 2 flute_meta # MetaCut View format
fmt L 2 oa_meta # MetaCut View format
fmt A 2 ta_meta # MetaCut View format
fmt TD 2 td_meta # MetaCut View format
fmt CD 2 cd_meta # MetaCut View format
fmt CL 2 cl_meta # MetaCut View format
fmt SD 2 sd_meta # MetaCut View format
fmt C 4 tipcomp # MetaCut View format
fmt 2 slot # 20004 Parameter line
fmt 2 tool_type
fmt 2 matl_type
fmt 2 corner_rad_type
fmt 2 diameter
fmt 2 corner_rad
fmt 2 threads
fmt A 2 tip_angle
fmt 2 dia_off
fmt 2 len_off
fmt 2 tool_feed
fmt 2 plunge
fmt 2 retract
fmt 2 rpm
fmt 2 coolant1
fmt 2 n_flutes1
fmt A 2 tip_angle_ch
fmt 2 cut_ability # 20006 Parameter line
fmt 2 step_r_xy
fmt 2 step_r_z
fmt 2 step_f_xy
fmt 2 step_f_z
fmt 2 tip_dia
fmt 2 min_dia
fmt 2 thd_ang
fmt 2 pilot_dia # 20007 Parameter line
fmt H 2 flute_len
fmt 2 oa_len
fmt 2 shldr_len
fmt 2 arbor_dia
fmt 2 hldr_dia
fmt 2 hldr_len
fmt 2 spindle_ccw
fmt 2 sfm
fmt 2 fpt
fmt 2 metric
fmt 2 stock # Amount of Stock left on drive surfs
fmt 2 check # Amount of Stock left on check surfs
fmt S 4 cyl_typ # Predator Cylindral Stock Type
fmt L 2 stck_ht
fmt W 2 stck_wdth
fmt H 2 stck_thck
fmt D 2 stck_diam
fmt X 2 stck_x
fmt Y 2 stck_y
fmt Z 2 stck_z
fmt X 2 stck_x_min
fmt Y 2 stck_y_min
fmt Z 2 stck_z_min
fmt X 2 stck_meta_ht
fmt Y 2 stck_meta_wdth
fmt Z 2 stck_meta_thck
fmt OX 2 stck_meta_ox
fmt OY 2 stck_meta_oy
fmt OZ 2 stck_meta_oz
fmt X 2 x_tmin # Total x_min
fmt X 2 x_tmax # Total x_max
fmt Y 2 y_tmin # Total y_min
fmt Y 2 y_tmax # Total y_max
fmt Z 2 z_tmin # Total z_min
fmt Z 2 z_tmax # Total z_max
fmt Z 2 min_depth # Tool z_min
fmt Z 2 max_depth # Tool z_max
fmt 2 vers_no # Mastercam version
fmt 2 m_vers_no # Minor version number
# Tool Comment / Manual Entry Section
ptoolcomment #Comment for tool
tnote = t
toffnote = tloffno
tlngnote = tlngno
tldianote = tldia
";", pstrtool, *tnote, *toffnote, *tlngnote, *tldianote, e
pstrtool #Comment for tool
if strtool <> sblank,
strtool = ucase(strtool)
*strtool, " "
pcomment #Comment from manual entry (must call pcomment2 if booleans)
pcomment2
pcomment2 #Comment from manual entry
spaces = 0
scomm = ucase (scomm)
#1005 - Comment option 1
#1006 - Comment option 2
#1007 - Define comment with output line
#1008 - Define NC parameter comment
#1026 - ?
if gcode = 1005, pbld, n, pspc, ";", scomm
if gcode = 1006, pbld, n, pspc, ";", scomm #Comments
#if gcode = 1006, pbld, n, pspc, scomm #Codes
if gcode = 1007, ";", scomm
if gcode = 1008, pbld, n, pspc, ";", scomm
if gcode = 1026, pbld, scomm
if gcode <> 1007 & gcode <> 1026, e
spaces = sav_spc
ptoolcomm # Comments from tool library
spaces = 0
strtool=ucase(strtool)
if strtool<>snull, pspc1, ";", *strtool, e
else, pspc1, ";", "DEFINE TOOL NAMES", e
spaces = sav_spc
plistcomm # Comments from tool library
if strtool<>snull, *strtool
else, "DEFINE TOOL NAMES"
if strtool=snull, stest1=snocomm+stilde
else, stest1=strtool+stilde
nstrlen = strstr(stilde,stest1)-1
counter = 1
while counter <= (25-nstrlen), pspace
pmetacomm # Comments from tool library
pspace # Creates spaces based on tool comment length
counter = counter + 1
ptspace # Creates spaces based on tool number
if t<10, " "
phspace # Creates spaces based on length offset number
if tlngno<10, " "
pdspace # Creates spaces based on diameter offset number
if tloffno<10, " "
pdiamspc # Creates spaces based on diameter offset number
if tldia<10, " "
pspc # Creates spaces based tool level setting
if sav_spc = one & omitseq = no, " "
pspc1 # Creates spaces based tool level setting
if sav_spc = one, " "
popnote # Operation note for tool table
if opcode = 3, *sdrnote
else, *sopnote
pstock # Comment amount of stock to leave
spaces=0
if (opcode=13 | opcode=14),
pbld, n, pspc, ";TOOLPATH - ", *stoper, e
pbld, n, pspc, ";STOCK LEFT ON DRIVE SURFS = ", *stock, e
if check<>0, pbld, n, pspc, ";STOCK LEFT ON CHECK SURFS = ", *check, e
spaces=sav_spc
ppredstck # Predator stock
spaces=0
q1
if stock_typ = 1,
cyl_typ = rot_on_x
q2
if stock_typ = 0, ppredbox
if stock_typ = 1,
if cyl_typ = 1, ppredcylx
if cyl_typ = 2, ppredcyly
if cyl_typ = 3, ppredcylz
spaces=sav_spc
ppredbox # Predator Box Stock
if stck_crnr = 0,
stck_x_min = stck_x - stck_ht/2
stck_y_min = stck_y - stck_wdth/2
if stck_crnr = 1 | stck_crnr = 5,
stck_x_min = stck_x
if stck_crnr = 2 | stck_crnr = 6,
if stck_crnr = 3 | stck_crnr = 7,
stck_y_min = stck_y
if stck_crnr = 4 | stck_crnr = 8,
stck_x_min = stck_x
stck_y_min = stck_y
if stck_crnr <= 4, stck_z_min = stck_z - stck_thck
else, stck_z_min = stck_z
"(SBOX ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_ht, " ", *stck_wdth, " ", *stck_thck, ")"
ppredcylx # Predator Cyl-X Stock
if stck_crnr = 0,
stck_y_min = stck_y
stck_x_min = stck_x
stck_y_min = stck_y + stck_wdth/2
stck_x_min = stck_x
if stck_crnr <= 4, stck_z_min = stck_z - stck_thck/2
else, stck_z_min = stck_z + stck_thck/2
stck_diam = stck_wdth
if stck_thck > stck_wdth, stck_diam = stck_thck
stck_ht = stck_ht
"(SCYL ", *cyl_typ, " ", *stck_x_min, " ", *stck_y_min, " ", *stck_z_min, " ", *stck_diam, " ", *stck_ht, ")"
ppredcyly # Predator Cyl-Y Stock
if stck_crnr = 0,
stck_x_min = stck_x
stck_x_min = stck_x + stck_ht/2
stck_y_min = stck_y
stck_y_min = stck_y
stck_diam = stck_ht
if stck_thck > stck_ht, stck_diam = stck_thck
stck_ht = stck_wdth
ppredcylz # Predator Cyl-Z Stock
if stck_crnr = 0,
stck_x_min = stck_x
stck_y_min = stck_y
stck_diam = stck_ht
if stck_wdth > stck_ht, stck_diam = stck_wdth
stck_ht = stck_thck
pmetastck # MetaCut View stock
if stck_crnr = 0,
stck_meta_ox = stck_x * m_one - (tox * m_one)
stck_meta_oy = stck_y * m_one - (toy * m_one)
stck_meta_ox = (stck_x + stck_ht/2) * m_one - (tox * m_one)
stck_meta_oy = (stck_y - stck_wdth/2) * m_one - (toy * m_one)
stck_meta_ox = (stck_x - stck_ht/2) * m_one - (tox * m_one)
stck_meta_oy = (stck_y + stck_wdth/2) * m_one - (toy * m_one)
if stck_crnr <= 4, stck_meta_oz = stck_z * m_one - (toz * m_one)
else, stck_meta_oz = (stck_z + stck_thck) * m_one - (toz * m_one)
stck_meta_ht = stck_ht
stck_meta_wdth = stck_wdth
stck_meta_thck = stck_thck
#(NWDSTOCK X8. Y8. Z1.25 OTC OX-4. OY-4. OZ0.)
spaces=0
"(NWDSTOCK ", *stck_meta_ht, " ", *stck_meta_wdth, " ", *stck_meta_thck,
" OTC ", *stck_meta_ox, " ", *stck_meta_oy, " ", *stck_meta_oz, ")"
spaces=sav_spc
pstop # Stop routine
pretract
pcom_moveb
if mi10=one, n, *sm00, e
pbld, n, pwcs, e
sav_absinc = absinc
if wcstype > one, absinc = zero
if lock_codes = 1 & not(index) & rot_on_x, pbld, n, *sunlock, ";UNLOCK", e
pcan1, pbld, n, *sgcode, *sgabsinc, pfxout, pfyout,
pfcout, *speed, *spindle, pgear, strcantext, e
if lock_codes = 1 & not(index) & rot_on_x & cuttype = 0, pbld, n, *slock, ";LOCK", e
pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool, e
sav_coolant = coolant
if coolant = 1, sm09 = sm09_0
if coolant = 2, sm09 = sm09_1
if coolant = 3, sm09 = sm09_2
absinc = sav_absinc
# Misc. Output
pparameter # Run parameter table
if opcode=13 | opcode=14, result = fprm (opcode)
if prmcode = 10000, stoper = ucase(sparameter)
if prmcode = 10055, spostname = ucase(sparameter)
if stoper=snull, stoper = snullop
pwrttparam #Information from parameters
if prmcode = 20004, slot = rpar(sparameter, 16)
if prmcode = 20006, cut_ability = rpar(sparameter,8)
if prmcode = 20007, pilot_dia = rpar(sparameter, 11)
# Start of File and Toolchange Setup
psof0 #Start of file for tool zero
psof
psof #Start of file for non-zero tool number
ptravel
pwritbuf5
pcuttype
toolchng = one
if ntools = one,
#skip single tool outputs, stagetool must be on
#stagetool = m_one
!next_tool
tooltotal = rbuf(4,0) #Reads total tool and null tool changes
if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)
else, nexttool = first_tool
if tool_table = 2, ppredstck
if tool_table = 3, pmetastck
spaces=0
if output_z = yes & tcnt > 1,
";OVERALL MAX : ", *z_tmax, e
";OVERALL MIN : ", *z_tmin, e
spaces=sav_spc
if plane < 0, plane = 0
pbld, n, *sgcode, *sgplane, "G40", "G44", *smetric, "G80", *sgabsinc, e
sav_absinc = absinc
if wcstype <= one, #Work coordinate system
absinc = one
pfbld, n, sgabsinc, "G28", "Z0.", e
pfbld, n, "G28", "X0.", "Y0.", e
pfbld, n, "G92", *xh, *yh, *zh, e
absinc = sav_absinc
sav_mi9 = mi9
sav_workofs = workofs
if sav_workofs < 0, sav_workofs = 0
ptlchg_com
ptlchg_com #Tool change common blocks
pcom_moveb
c_mmlt #Multiple tool subprogram call
#ptoolcomment
comment
pcan
if stagetool >= zero,
pbld, n, *t, ptoolcomm, e
pbld, n, "M06", e
spaces=0
if output_z = yes,
preadbuf5
if (opcode > 0 & opcode < 16) | opcode = 19,
n, pspc, ";", "MAX : ", *max_depth, e
n, pspc, ";", "MIN : ", *min_depth, e
spaces=sav_spc
pstock
pindex
pbld, n, pwcs, e
sav_absinc = absinc
absinc = sav_absinc
pcom_movea
toolchng = zero
c_msng #Single tool subprogram call
last_op_id = op_id
last_cuttype = cuttype
ptlchg0 #Call from NCI null tool change (tool number repeats)
pcuttype
pcom_moveb
toolcount = toolcount + 1
prvtp = rbuf(3,toolcountp)
if mi10=one & op_id<>last_op_id | (tlplnno <> prvtp & ret_on_indx), pstop
comment
pcan
pbld, n, sgplane, e
pspindchng
if coolant <> 0 & coolant <> sav_coolant, pbld, n, sm09, e
pbld, n, scoolant, e
if op_id<>last_op_id, pstock
if sav_mi9 = 1, workofs = sav_workofs
if (wcstype > one & workofs <> prv_workofs) | (tlplnno <> prvtp & ret_on_indx),
pbld, n, pwcs, e
sav_absinc = absinc
absinc = zero
if fmtrnd(prv_cabs) <> fmtrnd(cabs),
pbld, n, sgabsinc, pfxout, pfyout, pfzout, pfcout, e
else,
pbld, n, sgabsinc, pfxout, pfyout, pfzout, pcout, e
pe_inc_calc
ps_inc_calc
absinc = sav_absinc
if lock_codes = 1 & cuttype <> last_cuttype & cuttype > 0, pbld, n, *sunlock, ";UNLOCK", e
if cuttype = zero, ppos_cax_lin
if lock_codes = 1 & cuttype <> last_cuttype & cuttype = 0 & fmtrnd(prv_cabs) = fmtrnd(cabs), pbld, n, *slock, ";LOCK", e
if gcode = one, plinout
else, prapidout
pcom_movea
last_op_id = op_id
ptlchg #Tool change
pcuttype
toolchng = one
if wcstype = one, #Work coordinate system
pbld, n, *sm01, e
ptlchg_com
pretract #End of tool path, toolchange
sav_absinc = absinc
absinc = zero
coolant = zero
#cc_pos is reset in the toolchange here
cc_pos = zero
gcode = zero
pcan
pbld, n, sccomp, *sm05, psub_end_mny, e
pcan1, pbld, n, sgabsinc, sgcode, "G44", "G53", "Z0.", scoolant, strcantext, e
#if lock_codes = 1 & rot_on_x, pbld, n, *sunlock, ";UNLOCK", e
#pbld, n, "G53", "X0.", "Y0.", protretinc, e
#if lock_codes = 1 & rot_on_x & cuttype = 0, pbld, n, *slock, ";LOCK", e
if abs(cabs) > 360 & nextop <> 1003,
if lock_codes = 1, pbld, n, *sunlock, ";UNLOCK", e
pbld, n, 'G53', protretinc, e
if lock_codes = 1 & cuttype = 0, pbld, n, *slock, ";LOCK", e
pcan2
absinc = sav_absinc
coolant = sav_coolant
protretinc #Reset the C axis revolution counter
if frc_cinit & rot_on_x,
rev = zero
sav_rev = zero
cabs = zero
csav = zero
indx_out = zero
if index, e, pindxcalc, pindex
else, *cabs
prvcabs = zero
!csav, !cabs
peof0 #End of file for tool zero
peof
peof #End of file for non-zero tool
pretract
if lock_codes = 1 & rot_on_x, pbld, n, *slock, ";LOCK", e
comment
#Remove pound character to output first tool with staged tools
#if stagetool = one, pbld, n, *first_tool, e
n, *sg90, e
n, "M30", e
mergesub
clearsub
mergeaux
clearaux
27 #ESC Escape Character
#26 #EOF Enf of File Character
#128 #Reported to work by Jax Mold
#4 #EOT End of Tape Character
#fleader #Outputs 20 Null Characters if needed
pwcs #G54+ coordinate setting at toolchange
if wcstype = two | wcstype > three,
sav_frc_wcs = force_wcs
if sub_level, force_wcs = zero
if workofs < 0, workofs = 0
if workofs <> prv_workofs | (force_wcs & toolchng),
if workofs < 6,
g_wcs = workofs + 54
*g_wcs
else,
p_wcs = workofs - five
"G54.1", *p_wcs
force_wcs = sav_frc_wcs
!workofs
pgear #Find spindle gear from lookup table
if use_gear = one,
gear = frange (one, speed)
*gear
#Toolchange setup
pspindchng #Spindle speed change
if prv_spdir2 <> spdir2 & prv_speed <> zero, pbld, n, *sm05, e
if prv_speed <> speed | prv_spdir2 <> spdir2,
if speed, pbld, n, *speed, *spindle, pgear, e
!speed, !spdir2
pspindle #Spindle speed calculations for RPM
speed = abs(ss)
if maxss = zero | maxss > max_speed, maxss = max_speed
#zero indicates spindle off (not a mistake)
if speed,
if speed > max_speed, speed = maxss
if speed < min_speed, speed = min_speed
spdir2 = fsg3(spdir)
pq #Setup post based on switch settings
sav_spc = spaces
if stagetool = one, bldnxtool = one
#Rotaxtyp = 1 sets initial matrix to top
#Rotaxtyp = -2 sets initial matrix to front
if vmc, rotaxtyp = one
else, rotaxtyp = -2
#Shut off rotary axis if, Q164. Enable Rotary Axis button? n
if ucase(sq164) = strn, rot_on_x = zero
if arctype = one | arctype = four,
result = newfs(two, i)
result = newfs(two, j)
result = newfs(two, k)
else,
result = newfs(three, i)
result = newfs(three, j)
result = newfs(three, k)
if usecanned = yes, pusecannedyes
else, pusecannedno
pheader #Call before start of file
if met_tool = one, #Metric constants and variable adjustments
ltol = ltol_m
vtol = vtol_m
maxfeedpm = maxfeedpm_m
result = nwadrs(srotary, cabs)
result = nwadrs(srotary, cinc)
result = nwadrs(srotary, indx_out)
spaces=0
#"%99996"
#if progno = 0, progno = 99999
#"%", *progno, e
"%", *progname, ",MX,", e
spathnc = ucase(spathnc)
smcname = ucase(smcname)
#";PROGRAM NAME - ", sprogname, e
#";DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, e
";MASTERCAM - V", *vers_no, e
";MC9 FILE - ", smcpath, smcname, smcext, e
";POST - ", spostname, e
stck_matl = ucase(stck_matl)
";MATERIAL - ", stck_matl, e
";PROGRAM - ", sprogname, sextnc, e
";DATE - ", *smonth, "-", *day, "-", *year, e
";TIME - ", *time, e
";POST DEV - ", *slicense, e
spaces=sav_spc
if seqno = 0, omitseq = yes
sav_rot_on_x = rot_on_x
rot_on_x = 0
sav_progno = progno
#seqno = 10
#seqinc = 10
#n = seqno
ptoolend #End of tool path, before reading new tool data
!speed, !spdir2
ptlchg1002 #Call at actual toolchange, end last path here
if op_id <> last_op_id,
sav_rev = rev #Axis Sub does not update to rev
if one_rev = one, sav_rev = 0
pspindle
whatline = four #Required for vector toolpaths
if gcode = 1000,
#Null toolchange
else,
#Toolchange and Start of file
if gcode = 1002,
#Actual toolchange
pretract
if stagetool = one, prv_next_tool = m_one
prv_xia = vequ(xh)
prv_feed = c9k
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout #Output to NC of linear movement - rapid
pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, strcantext, scoolant, e
plinout #Output to NC of linear movement - feed
pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e
pcirout #Output to NC of circular interpolation
if hel_2100 = one, pcirout2
else, pcirout1
pcirout1 #Output to NC of circular interpolation
pcan1, pbld, n, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e
pcirout2 #Output to NC of circular interpolation
if (plane = zero & abs(zinc)>=0.0005)
| (plane = one & abs(xinc)>=0.0005)
| (plane = two & abs(yinc)>=0.0005), phelout
else, pcirout1
phelout #Output to NC of helical interpolation
lead = abs(zinc/sweep*360)
if plane = zero, result = nwadrs(strk, lead)
if plane = one, result = nwadrs(stri, lead)
if plane = two, result = nwadrs(strj, lead)
pxout, pyout, pzout, *lead, pcout, parc, feed, strcantext, scoolant, e
pcom_moveb #Common motion preparation routines, before
pxyzcout
ps_inc_calc
pncoutput #Movement output
pcom_moveb
comment
pbld, n, sm09, e
if cool_zmove = yes & (nextop=1003 | (nextop=1011 & t<>abs(nexttool))), coolant = zero
pcan
if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
if gcode = zero, prapidout
if gcode > one & gcode < four, pcirout
if mr_rt_actv, #Restore absolute/incremental for G51/G68
absinc = sav_absinc
mr_rt_actv = zero
pcom_movea
pcom_movea #Common motion preparation routines, after
pcan2
pe_inc_calc
pdwl_spd #Call from NCI gcode 4
pspindle
comment
pspindchng
pcan
if fmtrnd(dwell), pcan1, pbld, n, *sgcode, *dwell, strcantext, e
else, pcan1, pbld, n, strcantext, e
pcan2
prapid #Output to NC of linear movement - rapid
pncoutput
pzrapid #Output to NC of linear movement - rapid Z only
pncoutput
plin #Output to NC of linear movement - feed
pncoutput
pz #Output to NC of linear movement - feed Z only
pncoutput
pmx #Output to NC of vector NCI
pncoutput
pcir #Output to NC of circular interpolation
pncoutput
#Pre-process rotary motion control flags
pmx0 #5 axis gcode setup
if drillcur = zero,
if fr = -2, gcode = zero
else, gcode = one
plin0 #Linear movement, mill motion test
pmotion_su
pcir0 #Circular interpolation, mill arc motion test
pmotion_su
# Motion output components
pbld #Canned text - block delete
if bld, '/'
pfbld #Force - block delete
pccdia #Cutter Compensation
#Force Dxx#
if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno = c9k
sccomp
if cc_pos, tloffno
pfxout #Force X axis output
if absinc = zero, *xabs, !xinc
else, *xinc, !xabs
pxout #X output
if absinc = zero, xabs, !xinc
else, xinc, !xabs
pfyout #Force Y axis output
if absinc = zero, *yabs, !yinc
else, *yinc, !yabs
pyout #Y output
if absinc = zero, yabs, !yinc
else, yinc, !yabs
pfzout #Force Z axis output
if absinc = zero, *zabs, !zinc
else, *zinc, !zabs
pzout #Z output
if absinc = zero, zabs, !zinc
else, zinc, !zabs
pfcout #Force C axis output
if index = zero & rot_on_x,
if absinc = zero, *cabs, !cinc
else, *cinc, !cabs
pcout #C axis output
if absinc = zero, cabs, !cinc
else, cinc, !cabs
pindex #Index output
if index & rot_on_x,
if fmtrnd(prv_indx_out) <> fmtrnd(indx_out),
pbld, n, `sindx_mc, indx_out, e
!cabs, !cinc
parc #Select the arc output
if arcoutput = zero | full_arc_flg | arc_pitch,
#Arc output for IJK
# If you do NOT want to force out the I,J,K values,
# remove the "*" asterisks on the *i, *j, *k 's below...
if plane = zero, *i, *j, k #XY plane code - G17
if plane = one, i, *j, *k #YZ plane code - G19
if plane = two, *i, j, *k #XZ plane code - G18
else,
#Arc output for R
if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
else, result = nwadrs(srminus, arcrad)
*arcrad
ppos_cax_lin #Position the rotary axis before move - rapid
if index, pindex
else,
if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x,
sav_gcode = gcode
gcode = zero
if lock_codes = 1 & not(index), pbld, n, *sunlock, ";UNLOCK", e
pbld, n, sgcode, pcout, e
if lock_codes = 1 & not(index) & cuttype = 0, pbld, n, *slock, ";LOCK", e
!cia
ps_cinc_calc
gcode = sav_gcode
# Drilling
pdrill0 #Pre-process before drill call
sav_dgcode = gcode #Capture gcode for 5 axis drill
pdrlcommonb #Canned Drill Cycle common call, before
if sav_dgcode = 81,
result = newfs (two, zinc)
if drillcyc = three, drlgsel = fsg1(-ss) + drillcyc * two
else, drlgsel = fsg2(dwell) + drillcyc * two
if initht <> refht, drillref = zero
else, drillref = one
prv_refht_a = c9k
prv_refht_i = c9k
prv_dwell = zero
if cuttype = three, sav_dgcode = gcode
else, z = depth
if cuttype = one, prv_zia = initht + (rotdia/two)
else, prv_zia = refht #Fanuc style - G91 Z depth from R level
#else, prv_zia = initht #G91 Z depth from initial height
feed = fr_pos
pcom_moveb
comment
pcan
#5 axis must map the true Z, correct Z calculation here
if cuttype = three,
prv_zia = zabs + (-depth) + initht
zia = fmtrnd(zabs)
zinc = zia - prv_zia
else, zinc = depth - refht
result = nwadrs(stri, zabs)
result = nwadrs(stri, zinc)
dwell_out = dwell * 100
prdrlout #R drill position
if cuttype = one, refht_a = refht + (rotdia / two))
else, refht_a = refht
refht_i = refht - initht
if cuttype = three, refht_a = w
if absinc = zero, refht_a, !refht_i
else, refht_i, !refht_a
pdrill #Canned Drill Cycle
pdrlcommonb
pcan1, pbld, n, *sgdrill, *sgdrlref, pxout, pyout, prdrlout, pfzout, pcout,
dwell_out, *feed, strcantext, e
pcom_movea
ppeck #Canned Peck Drill Cycle
pdrlcommonb
numpeck = abs((depth - refht)/peck1)
if frac(numpeck)<>0, numpeck=numpeck+1
numpeckint = int(numpeck)
peck1 = (depth - refht)/numpeckint
pcan1, pbld, n, *sgdrill, *sgdrlref, pxout, pyout, prdrlout, !zabs, !zinc, pcout,
*peck1, *numpeckint, *feed, strcantext, e
pcom_movea
pchpbrk #Canned Chip Break Cycle
if peck2 = 0, peck2 = 1
if shftdrl = 0, shftdrl = 1
bval = peck1
dval = refht - zdrl
*bval, *peckclr, *dval, *retr, *peck2, *shftdrl, dwell_out, *feed, strcantext, e
pcom_movea
ptap #Canned Tap Cycle
pdrlcommonb
#tool_typ = 4 - RH, 5 - LH
feed = speed/n_tap_thds #Override V8.1 parameter feed
prigid, *feed, strcantext, e
pcom_movea
tapflg = 1
prigid #Rigid Tap Cycle Toggle
if peck1=1, "R1"
else, "R0"
pbore1 #Canned Bore #1 Cycle
pdrlcommonb
pcom_movea
pbore2 #Canned Bore #2 Cycle
pdrlcommonb
pcom_movea
pmisc1 #Canned Misc #1 Cycle
pdrlcommonb
pcom_movea
pmisc2 #Canned Misc #2 Cycle (User Option)
pdrill
pdrill_2 #Canned Drill Cycle, additional points
pdrlcommonb
pcan1, pbld, n, pxout, pyout, prdrlout, pzout, pcout, dwell_out,
feed, strcantext, e
pcom_movea
ppeck_2 #Canned Peck Drill Cycle
pdrill_2
pchpbrk_2 #Canned Chip Break Cycle
pdrill_2
ptap_2 #Canned Tap Cycle
pdrill_2
pbore1_2 #Canned Bore #1 Cycle
pdrill_2
pbore2_2 #Canned Bore #2 Cycle
pdrill_2
pmisc1_2 #Canned Misc #1 Cycle
pdrill_2
pmisc2_2 #Canned Misc #2 Cycle
pdrill_2
pdrlcst #Custom drill cycles 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
#if drillcyc = 8, pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
# prdrlout, dwell, *feed, strcantext, e
if drillcyc = 8,
sub_prg_call = peck1
pcan1, pbld, n, *sg00, *sgabsinc, pfxout, pfyout, strcantext, e
spaces = 0
pbld, n, pspc, "(", "CALL ", *sub_prg_call, ")", e
spaces = sav_spc
else, "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e
pcom_movea
pdrlcst_2 #Custom drill cycles 8 - 19, additional points (user option)
pdrlcommonb
#if drillcyc = 8, pcan1, pbld, n, pxout, pyout, pzout, pcout, prdrlout, dwell,
# feed, strcantext, e
if drillcyc = 8,
spaces = 0
spaces = sav_spc
pcom_movea
pcanceldc #Cancel canned drill cycle
result = newfs (three, zinc)
z = initht
pxyzcout
!zabs, !zinc
prv_gcode = zero
pcan
if drillcyc <> 8, pcan1, pbld, n, "G80", scoolant, strcantext, e
if use_pitch & tapflg = 1, pbld, n, "G94", e
pcan2
tapflg = 0
#Subprogram postblocks
#sub_trnstyp - 0=mirror, 1=rotate, 2=scale, 3=translate
#sub_trnmthd (mirror) - 0=X axis, 1=Y axis, 2=line
#sub_trnmthd (rotate) - 0=tplane, 1=tplane origin only, 2=coordinates
psub_call_m #Call to main level, single tool
psub_call_trans
psub_call_mm #Call to main level, multiple tools
psub_call_trans
psub_call_trans #Translate level calls from toolchange, user
if wcstype <= one, result = mprint(shomeserror)
sav_absinc = absinc
pindex
#Mirror or Rotate Coord's
if sub_trnstyp = zero | (sub_trnstyp = one & mr_rt_actv),
#The original pattern is not mirrored or rotated
if sub_sec_no,
absinc = zero
if sub_trnstyp, psub_rotate
else, psub_mirror
mr_rt_actv = three
else, #Translate
if sub_mny_t,
pbld, n, pwcs, e
pbld, n, *sgcode, *sgabsinc, pfxout, pfyout, pfzout,
pfcout, e
pe_inc_calc
ps_inc_calc
absinc = sav_absinc
result = nwadrs(snull, main_prg_no)
main_prg_no = main_prg_no + sav_progno #Add sub number offset
if sav_progno = main_prg_no, result = mprint(sprgnerror)
spaces = 0
pbld, n, pspc, "(", "CALL ", *main_prg_no, ")", e
spaces = sav_spc
prv_feed = c9k #Force feed in sub
psub_mirror #Mirror start code, user
#Mirror Y axis
if sub_trnmthd, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsx, e
#Mirror X axis
else, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsy, e
psub_rotate #Rotate start code, user
pbld, n, *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx, *sub_trnsy,
[absinc = one], *sgabsinc, *rt_cinc, e
psub_st_m #Header in main level
#sav_n1 = n
#n = seqno
" ", e
spaces = 0
#*main_prg_no, ",MX,", e
"(SUB ", *main_prg_no, ")", e
if scomm0 <> snull, ";", *scomm0, e
spaces = sav_spc
#G51/G68 requires absolute position on first move
if mr_rt_actv & absinc = one,
sav_absinc = absinc
absinc = zero
prv_absinc = m_one
prv_xabs = m_one
prv_yabs = m_one
else, pbld, n, sgabsinc, e
psub_end_m #End in main level
"(RET)", e
prv_absinc = -1
#n = sav_n1
#Reset update variables for subs at main level
#Mirror or Rotate cancel, output is forced
if (sub_trnstyp = zero & esub_sec_no > zero)
| (sub_trnstyp = one & esub_sec_no = esub_totl_no-one
& sub_trnmthd = two),
subout = zero
no_nc_out = m_one
sav_absinc = absinc
#Mirror cancel
if sub_trnstyp = zero,
absinc = zero
pbld, n, *sgabsinc, strns_mir_off, *sub_trnsx, *sub_trnsy, e
else, #Rotate cancel
pbld, n, strns_rot_off, e
absinc = sav_absinc
no_nc_out = zero
end_sub_mny = sub_mny_t
psub_end_mny #End in main level for many tools sub, user
#Check for coming out of xform with stage tool.
if end_sub_mny & stagetool = one,
*t
end_sub_mny = zero
psub_call_s #Call to sub level
result = nwadrs(snull, sub_prg_no)
sub_prg_no = sub_prg_no + sav_progno + 1000 #Add sub number offset
if sav_progno = sub_prg_no, result = mprint(sprgnerror)
spaces = 0
pbld, n, pspc, "(", "CALL ", *sub_prg_no, ")", e
spaces = sav_spc
psub_st_s #Header in sub level
#sav_n2 = n
#n = seqno
" ", e
spaces = 0
#*sub_prg_no, ",MX,", e
"(SUB ", *sub_prg_no, ")", e
spaces = sav_spc
psub_end_s #End in sub level
"(RET)", e
prv_absinc = -1
#n = sav_n2
# Canned Text
pcan #Canned text - before output call
strcantext = sblank
if cant_no > zero,
if cant_pos1 = zero, pcant_1
if cant_pos2 = zero, pcant_2
if cant_pos3 = zero, pcant_3
if cant_pos4 = zero, pcant_4
if cant_pos5 = zero, pcant_5
if cant_pos6 = zero, pcant_6
if cant_pos7 = zero, pcant_7
if cant_pos8 = zero, pcant_8
if cant_pos9 = zero, pcant_9
if cant_pos10 = zero, pcant_10
strcantext = sblank
pcan1 #Canned text - with move
strcantext = sblank
if cant_no > zero,
if cant_pos1 = one, pcant_1
if cant_pos2 = one, pcant_2
if cant_pos3 = one, pcant_3
if cant_pos4 = one, pcant_4
if cant_pos5 = one, pcant_5
if cant_pos6 = one, pcant_6
if cant_pos7 = one, pcant_7
if cant_pos8 = one, pcant_8
if cant_pos9 = one, pcant_9
if cant_pos10 = one, pcant_10
if cstop, strcantext = strcantext + sm00
if cgstop, strcantext = strcantext + sm01
#Output of strcantext occurs at the end of the output line
pcan2 #Canned text - after output call
strcantext = sblank
if cant_no > zero,
if cant_pos1 = two, pcant_1
if cant_pos2 = two, pcant_2
if cant_pos3 = two, pcant_3
if cant_pos4 = two, pcant_4
if cant_pos5 = two, pcant_5
if cant_pos6 = two, pcant_6
if cant_pos7 = two, pcant_7
if cant_pos8 = two, pcant_8
if cant_pos9 = two, pcant_9
if cant_pos10 = two, pcant_10
strcantext = sblank
pcant_1 #Canned text - output call
cantext = cant_val1
pcant_out
pcant_2 #Canned text - output call
cantext = cant_val2
pcant_out
pcant_3 #Canned text - output call
cantext = cant_val3
pcant_out
pcant_4 #Canned text - output call
cantext = cant_val4
pcant_out
pcant_5 #Canned text - output call
cantext = cant_val5
pcant_out
pcant_6 #Canned text - output call
cantext = cant_val6
pcant_out
pcant_7 #Canned text - output call
cantext = cant_val7
pcant_out
pcant_8 #Canned text - output call
cantext = cant_val8
pcant_out
pcant_9 #Canned text - output call
cantext = cant_val9
pcant_out
pcant_10 #Canned text - output call
cantext = cant_val10
pcant_out
pcant_out #Canned text - build the string for output
#Assign string select type outputs
if cantext = three, bld = one
if cantext = four, bld = zero
#Build the cantext string
if cantext = one, strcantext = strcantext + sm00
if cantext = two, strcantext = strcantext + sm01
if cantext > four,
strtextno = no2str(cantext)
strcantext = strcantext + strm + strtextno
# Position calculations, generally these do not need to be modified
pmiscint #Capture the top level absinc for subprograms
if sub_level <= zero, absinc = mi2
#Disable cutpos2 if not 4 axis, saves time
if rot_on_x = zero, cutpos2 = m_one
pusecannedyes # Use canned drilling cycles
usecandrill = yes # Use canned cycle for drill
usecanpeck = yes # Use canned cycle for Peck
usecanchip = yes # Use canned cycle for Chip Break
usecantap = yes # Use canned cycle for Tap
usecanbore1 = yes # Use canned cycle for Bore1
usecanbore2 = yes # Use canned cycle for Bore2
usecanmisc1 = yes # Use canned cycle for Misc1
usecanmisc2 = yes # Use canned cycle for Misc2
pusecannedno # Use canned drilling cycles
usecandrill = no # Use canned cycle for drill
usecanpeck = no # Use canned cycle for Peck
usecanchip = no # Use canned cycle for Chip Break
usecantap = no # Use canned cycle for Tap
usecanbore1 = no # Use canned cycle for Bore1
usecanbore2 = no # Use canned cycle for Bore2
usecanmisc1 = no # Use canned cycle for Misc1
usecanmisc2 = no # Use canned cycle for Misc2
pmotion_su #Motion Setup (Set brklinestype & linarc)
brklinestype = zero
linarc = zero
if rot_on_x,
if cuttype = one, linarc = one #Axis subs
if cuttype = two, #Polar
brklinestype = rotary_axis + three
linarc = one
pcuttype #Determine the cut type
#cuttype (0 = Tool Plane, 1 = Axis Subs, 2 = Polar, 3 = 4/5 axis)
cuttype = rotary_type
if cuttype = three, cuttype = zero
if mill5,
if rot_on_x = zero, result = mprint(saxisoff)
cuttype = three
if rotary_axis,
if rotary_axis <> rot_on_x, result = mprint(saxiswarn)
rot_on_x = rotary_axis
#Check for Tool Origin in Polar Milling
if cuttype = two & (tox | toy | toz), result = mprint(stlorgerr)
#Transform Rotate, set mr_rt_actv if user selected 'coordinates'
if sub_trnstyp = one & sub_trnmthd = two,
#Calculate the rotation incremental angle for G68
rt_csav = atan2(sub_m2, sub_m1)
rt_cinc = prv_rt_csav - rt_csav
while rt_cinc > 180, rt_cinc = rt_cinc - 360
while rt_cinc < -180, rt_cinc = rt_cinc + 360
if rot_ccw_pos = one, rt_cinc = -rt_cinc
!rt_csav
if sub_sec_no, mr_rt_actv = two
else, mr_rt_actv = one
else, mr_rt_actv = zero
pfcalc_u_min
pmotion_su
pxyzcout #Map coordinates
if rot_on_x,
if cuttype = zero, pxyzcout0 #Toolplane Positioning
if cuttype = one, pxyzcout1 #Axis Substitution
if cuttype = two, pxyzcout2 #Polar Conversion
if cuttype = three, pxyzcout3 #Simulatneous 4 axis (Multi-axis)
if rot_ccw_pos = one, csav = -csav
if mr_rt_actv <> two,
pcoutrev
if index, pindxcalc
pfcalc
else, feed = fr_pos
else,
xabs = vequ (x)
feed = fr_pos
xabs = vequ (x)
if cuttype = 2 & rot_on_x = two & vmc, c = atan2(vtoolx,-vtooly)
if rot_on_x = two, csav = -c
else, csav = c
pxyzcout1 #Axis substitution
if rot_on_x = one, #X axis substitution
xabs = x
yabs = zero
zabs = z + (rotdia / two)
csav = y * (360 / (pi * rotdia))
else, #Y axis substitution
xabs = zero
yabs = y
csav = -x * (360 / (pi * rotdia))
if c <> 0,
else, csav = c
pxyzcout2 #polar interpolation
#Drill polar is toolplane drilling toward center
#if not a coincident axis
#Also, Capture initial index position for Polar Milling
if (opcode = three & rot_on_x <> three), pxyzcout0
else,
if rot_on_x = one, #X axis rotation
csav = atan2(y, z) #Z+ zero
axisx = vequ(aaxisx)
xabs = rotp(csav, x)
if rot_on_x = two, #Y axis rotation
csav = atan2(-x, z) #Z+ zero
axisx = vequ(baxisx)
if rot_on_x = three, #Z axis rotation
csav = atan2(-y, x) #X+ zero
axisx = vequ(caxisx)
csav = csav + c
pxyzcout3 #Multisurf rotary axis motion
if rot_on_x = one, #Multisurf Rotary about X
csav = atan2 (vtooly, vtoolz)
axisx = vequ (aaxisx)
if rot_on_x = two, #Multisurf Rotary about Y
csav = atan2 (-vtoolx, vtoolz)
axisx = vequ (baxisx)
xabs = rotp (csav, x)
u = rotp (csav, u)
csav = csav + c
pcoutrev #Rotary axis revolution calculation (Modify for wind-up)
cdelta = -(csav - prv_csav)
while abs(cdelta) > ctol, #If motion exceeds ctol, add wind-up
if cdelta > zero,
rev = rev - one
cdelta = cdelta - 360
else,
rev = rev + one
cdelta = cdelta + 360
if cuttype <> one, cabs = rev * 360 + csav
else, cabs = sav_rev * 360 + csav
if (cuttype = zero | opcode = 3 | (gcode = 0 & cuttype <> one)) & one_rev = one,
while fmtrnd(cabs) >= 360,
cabs = cabs - 360
rev = rev - 1
while fmtrnd(cabs) < 0,
cabs = cabs + 360
rev = rev + 1
#while fmtrnd(cabs) < -360,
# cabs = cabs + 720
# rev = rev + 2
if abs(cdelta) >= 0.0005, prv_cabs = c9k
!csav
pindxcalc #Index move calculations, direction is shortest
#Check if in tolerance
cdelta = frac(abs(csav)/ctable)
if cdelta > ixtol & cdelta < 1-ixtol,
result = mprint(sindxerror)
cdelta = prvcabs - cabs
#Phase shift delta 10 revolutions, check odd/even
if frac(int((cdelta + 3600)/180)/two), indx_mc = one
else, indx_mc = zero
#Set range 0-360
indx_out = csav
while indx_out < 0, indx_out = indx_out + 360
while indx_out > 360, indx_out = indx_out - 360
#Feedrate calculations
pfcalc #Feedrate calculations, gcode 0 does not evaluate
if gcode <> zero,
if abs(fmtrnd(cabs)-prvcabs) <= 0.001 | index | not(rot_feed) | opcode = 3, pfcalc_u_min
else,
#if cuttype = one & (cutpos2 <= one), #Proposed change
if cuttype = one & (cutpos2 <= one | cutpos2 = four & (opcode < 5 & opcode > 12)),
pfcalc_u_min
else, pfclc_deg_inv
if ipr_type <> prv_ipr_type, prv_feed = c9k
pfcalc_u_min #Feedrate unit/min
ipr_type = zero
feed = fr_pos
if feed > maxfeedpm, feed = maxfeedpm
prvfrdeg = feed
pfclc_deg_inv #Feedrate deg/min
circum = zabs * two * pi
if circum = zero, circum = c9k #Don't allow Zero
ldelta = sqrt((xabs-prv_xabs)^2+(yabs-prv_yabs)^2+(zabs-prv_zabs)^2)
cdelta = ((abs(cabs - prvcabs))/360)*circum
if ldelta = zero, cldelta = cdelta
else, cldelta = sqrt(cdelta^two + ldelta^two)
if cldelta = zero, cldelta = c9k
if use_frinv,
#Feedrate inverse calculation
ipr_type = two
prv_feed = c9k #Always force feed
frinv = fr_pos/cldelta
if rot_feed & opcode <> 3,
if frinv > maxfrinv, frinv = maxfrinv
feed = frinv
else,
#Feedrate deg/min control and calculation
ipr_type = zero #Change to ipr_type = one to force new DPM
frdeg = abs(cdelta/cldelta) * abs(fr_pos * (360/circum))
if abs(frdeg - prvfrdeg) > frdegstp | ipr_type <> prv_ipr_type,
#Control output of frdeg
prvfrdeg = frdeg
feed = frdeg
if frdeg > maxfrdeg & rot_feed, feed = maxfrdeg
#Incremental calculations
ps_inc_calc #Incremental calculations, start
xia = fmtrnd(xabs)
yia = fmtrnd(yabs)
zia = fmtrnd(zabs)
xinc = vsub (xia, prv_xia)
ps_cinc_calc
ps_cinc_calc #Incremental calculations, start rotary
cia = fmtrnd(cabs)
cinc = cia - prv_cia
pe_inc_calc #Incremental calculations, end
prvcabs = fmtrnd(cabs) #Avoid updating until called explicitly
!xia, !yia, !zia, !cia
!x, !y, !z
# Tooltable Output
pwrtt # Write tool table, scans entire file, null tools are negative
if rotaxis > 0 | rotary_type > 0 | mill5 <> 0,
rot_on_x = sav_rot_on_x
output_z = no
#if vmc = 0 & tlplnno <> 2, rot_on_x = sav_rot_on_x
#if vmc = 1 & tlplnno > 1, rot_on_x = sav_rot_on_x
if tlplnno > 1, rot_on_x = sav_rot_on_x
tlplnno = wbuf(3,wc3) #Buffers out tool plane values
t = wbuf(4,wc4) #Buffers out tool number values
if tool_table = 1, ptooltable
if tool_table = 2, ppredtool
if tool_table = 3, pmetatool
if t >= zero, tcnt = tcnt + one
ptravel
pwritbuf5
ptooltable # Write tool table, scans entire file, null tools are negative
tnote = t
toffnote = tloffno
tlngnote = tlngno
spaces=0
if t >= zero, ";", *t, ptspace, " : ", plistcomm, " : ", *tldia, punit, " : ", popnote
#if t >= zero,
# if tcr>0, ";", *t, ptspace, " : ", plistcomm, " : ", *tlngno, phspace, " : ", *tloffno, pdspace, " : ", *tldia, punit, " : ", *tcr, " : ", popnote
# if tcr=0, ";", *t, ptspace, " : ", plistcomm, " : ", *tlngno, phspace, " : ", *tloffno, pdspace, " : ", *tldia, punit, " : ", " : ", popnote
#if t >= zero,
# if tcr>0, ";", *tnote, " ", *toffnote, " ", *tlngnote, " ", *tldia, " ", *tcr, " ", popnote
# if tcr=0, ";", *tnote, " ", *toffnote, " ", *tlngnote, " ", *tldia, " ", popnote
spaces=sav_spc
punit # Tool unit
if met_tool, "mm", pdiamspc
else, 34, pdiamspc
ptravel # Tool travel limit calculation
if x_min < x_tmin, x_tmin = x_min
if x_max > x_tmax, x_tmax = x_max
if y_min < y_tmin, y_tmin = y_min
if y_max > y_tmax, y_tmax = y_max
if z_min < z_tmin, z_tmin = z_min
if z_max > z_tmax, z_tmax = z_max
ppredtool # Write tool setup info for Predator Virtual CNC
#if tool_typ = 1, styp1 # CENTER DRILL 1 - NTG/S4
#if tool_typ = 2, styp2 # SPOT DRILL 2 - S4
#if tool_typ = 3, styp3 # DRILL 3 - S4
#if tool_typ = 4, styp4 # TAP-RH 4 - S4 - MAX 179 ANGLE
#if tool_typ = 5, styp5 # TAP-LH 5 - S4 - MAX 179 ANGLE
#if tool_typ = 6, styp6 # REAMER 6 - S3/S1/S2
#if tool_typ = 7, styp7 # BORING BAR 7 - S3/S1/S2
#if tool_typ = 8, styp8 # COUNTER BORE 8 - NTG
#if tool_typ = 9, styp9 # COUNTER SINK 9 - NTG/S4
#if tool_typ = 10, styp10 # END MILL FLAT 10 - S1
#if tool_typ = 11, styp11 # END MILL SPHERE 11 - S2
#if tool_typ = 12, styp12 # CHAMFER MILL 12 - S7/NTG
#if tool_typ = 13, styp13 # FACE MILL 13 - S7/S9/NTG
#if tool_typ = 14, styp14 # SLOT MILL 14 - NTG/S1
#if tool_typ = 15, styp15 # CORNER RAD MILL 15 - S5/FLAT
#if tool_typ = 16, styp16 # DOVETAIL MILL 16 - DOVETAIL/NTG
#if tool_typ = 17, styp17 # TAPER MILL 17 - S7/S9/S10
#if tool_typ = 18, styp18 # LOLLIPOP MILL 18 - S6
#if tool_typ = 19, styp19 # END MILL BULL 19 - S3
tcr_pred = tcr
tldia_pred = tldia
tip_angle_ch = tip_angle*2
spaces=0
if t >= zero,
# CENTER DRILL
if tool_typ = 1, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
# SPOT DRILL
if tool_typ = 2, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
# DRILL
if tool_typ = 3, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
# TAP-RH
if tool_typ = 4,
if tip_angle <= 179, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
else, "(MTOOL ", *t, " ", *tldia_pred, " ", "A179.", " ", *flute_len, " S4)"
# TAP-LH
if tool_typ = 5,
# REAMER
if tool_typ = 6,
if tcr = 0, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
if tcr = tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S2)"
if tcr > 0 & tcr < tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)"
# BORING BAR
if tool_typ = 7,
# COUNTER BORE
if tool_typ = 8,
# COUNTER SINK
if tool_typ = 9, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S4)"
# END MILL FLAT
if tool_typ = 10, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
# END MILL SPHERE
if tool_typ = 11, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S2)"
# CHAMFER MILL
if tool_typ = 12, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle_ch, " ", *flute_len, " S7)"
# FACE MILL
if tool_typ = 13, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
# SLOT MILL
if tool_typ = 14, "(MTOOL ", *t, " ", *tldia_pred, " ", *flute_len, " S1)"
# CORNER RAD MILL
if tool_typ = 15,
else, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S5)"
# DOVETAIL MILL
if tool_typ = 16, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S8)"
# TAPER MILL
if tool_typ = 17,
if tcr = 0, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S7)"
if tcr = tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *tip_angle, " ", *flute_len, " S9)"
if tcr > 0 & tcr < tlrad, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *tip_angle, " ", *flute_len, " S10)"
# LOLLIPOP MILL
if tool_typ = 18, "(MTOOL ", *t, " ", *tldia_pred, " S6)"
# END MILL BULL
if tool_typ = 19, "(MTOOL ", *t, " ", *tldia_pred, " ", *tcr_pred, " ", *flute_len, " S3)"
spaces=sav_spc
pmetatool # Write tool setup info for MetaCut View
tcr_meta = tcr
if tool_typ = 13 | tool_typ = 17, tldia_meta = tldia + (2 *(flute_len * tan(tip_angle))
else, tldia_meta = tldia
if cctotip = 0, tipcomp = 1
else, tipcomp = 0
if tool_typ = 10 | opcode = 3, tipcomp = 0
if tool_typ = 12, td_meta = tip_dia
else, td_meta = 0
if tool_typ = 13 | tool_typ = 17, td_meta = tldia
flute_meta = flute_len
oa_meta = oa_len
ta_meta = tip_angle
cd_meta = hldr_dia
cl_meta = hldr_len
sd_meta = cd_meta
#(NWDTOOL NAME"1/2 CHAMFER MILL" T1 D.5 R0. F2. L3. A45. TD.06 CD2. CL1. SD2. C0)
# N = "Tool name"
# T = Tool No.
# D = Tool Dia.
# R = Corner Radius
# F = Flute Length
# L = Tool over all length
# A = Tip angle or Taper angle
# TD = Tip Dia.
# CD = Colllet/Holder Dia.
# CL = Collet/Holder Height
# SD = Spindle Dia. (set equal to Collet Diameter)
# C = tip or center 0 = tip 1 = center
spaces=0
if t >= zero, "(NWDTOOL N", 34, pmetacomm, 34, " ", *t, " ", *tldia_meta, " ",
[if tcr_meta > 0, *tcr_meta, " "], *flute_meta, " ", *oa_meta, " ",
[if ta_meta<>180, *ta_meta, " "], [if td_meta > 0, *td_meta, " "],
*cd_meta, " ", *cl_meta, " ", *sd_meta, " ", *tipcomp, ")"
spaces=sav_spc
# Buffer 5 Read / Write Routines
pwritbuf5 # Write Buffer 1
b5_gcode = gcode
b5_zmin = z_min
b5_zmax = z_max
b5_gcode = wbuf(5, wc5)
preadbuf5 # Read Buffer 1
size5 = rbuf(5,0)
b5_gcode = 1000
min_depth = 99999
max_depth = -99999
while rc5 <= size5 & b5_gcode = 1000,
if rc5 <= size5, b5_gcode = rbuf(5,rc5)
if b5_zmin < min_depth, min_depth = b5_zmin
if b5_zmax > max_depth, max_depth = b5_zmax
# Numbered questions for Mastercam
38. Rapid feedrate? 300.0
1538. Rapid feedrate (metric)? 10000.0
#76. Configuration file name?
80. Communications port number for receive and transmit (1 or 2) ? 2
81. Data rate (110,150,300,600,1200,2400,4800,9600,14400,19200,38400)? 9600
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 2
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0
87. Ascii, Eia, or Binary (A/E/B)? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor? RP
93. Reverse post PST file name? RPFAN
100. Number of places BEFORE the decimal point for sequence numbers? 0
101. Number of places AFTER the decimal point for sequence numbers? 0
103. Maximum spindle speed? 10000
107. Average time for tool change (seconds)? 2.0
161. Enable Home Position button? y
162. Enable Reference Point button? y
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? y
165. Enable Tool Plane button? y
166. Enable Construction Plane button? y
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? y
# Default Miscellaneous Real Values
201. Default miscellaneous real variable 1 (mr1)? 0.0
202. Default miscellaneous real variable 2 (mr2)? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Miscellaneous integer variable 1 (mi1)? 0
302. Absolute or Incremental [0=ABS,1=INC] (mi2)? 0
303. Miscellaneous integer variable 3 (mi3)? 0
304. Miscellaneous integer variable 4 (mi4)? 0
305. Miscellaneous integer variable 5 (mi5)? 0
306. Miscellaneous integer variable 6 (mi6)? 0
307. Miscellaneous integer variable 7 (mi7)? 0
308. Miscellaneous integer variable 8 (mi8)? 0
309. Lock on First WCS [0=No,1=Yes] (mi9)? 0
310. M00 before operation [0=No,1=Yes] (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? y
1520. Display a warning when cutter compensation in control simulation finds an error? n
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
3001. Machine acceleration? 2
3002. timing size? .1
