588,201 active members*
4,401 visitors online*
Page 11 of 12 9101112
Results 201 to 220 of 233
  1. #201
    Jun 2012
    Any chance of the drawing [email protected] .10x in advance
  2. #202
    Jul 2012
    I would like to build such a machine. My question would be, how reliable and accurate? Especially I would like to bite her trees, musical instruments and make my job easier I would like.
  3. #203
    Jul 2005
    18
    need dxf file
    scan0001.pdf can someone make a dxf of this please.
  4. #204
    Aug 2004
    3215
    Quote Originally Posted by jerry1957 View Post
    The edges of the original are poor quality, but this is best i can do with it right now, If you could get a better crisper scan it will be better.
    Attached Files Attached Files
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  5. #205
    Jun 2014
    Re: Joes CNC Model 2006 R-1
    Hi, I can't download your zip file, please help
    thanks
    Pat,
  6. #206
    Aug 2015
    38
    Hi!
    I was wondering if it's possible to replace the HDPE with acrylic? HDPE is extremelly expensive in my country.
  7. #207
    Aug 2004
    3215
    Some have done it but the acrylic can be brittle. I had made some of my hybrid out of acrylic and it worked.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  8. #208
    Aug 2015
    38
    Hey Joe, thanks for the reply!!
    What about high molecular weight polyethylene (HMWPE)?
    Thanks a lot!
  9. #209
    Aug 2004
    3215
    Quote Originally Posted by inicdam View Post
    Thanks a lot!
    You may want to look at the tensile strength, I think it may be lower than HDPE but in this application may be just fine. Also I believe that some of those materials is oil impregnated for self lubrication so this would have to be taken into consideration then using washers, surface contact areas etc, there may not be good friction to avoid loosening, may need to switch to locking nuts in places. there is allot of vibrations when cutting various materials. which can over time loosen bolts (which should be check periodically anyway).
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  10. #210
    Aug 2015
    38
    Thanks a lot Joe, luckily I was able to find a piece of HDPE
    Regards!
  11. #211
    Aug 2004
    3215
    good to hear.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  12. #212
    Aug 2015
    38
    Hey guys, just a stupid question, how do you prevent the bed from being cut?
    For instance if I use a bed like this with rails (I am planning to use one like that to clamp the piece to cut)?
    Attachment 290666
    I have red that you can limit the Z axis depth, but only one mm mistake and the bed is scratched.
    Sorry again for the silly question.
    Regards!
  13. #213
    Aug 2004
    3215
    He will probably glue aspoil board on top of that and then when it gets worn resurface it many times, then when it gets to low, resurface then add another spoil board on top and do a final surface.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  14. #214
    Aug 2015
    38
    Ah, little detail I didn't know about the spoil board.
    Sorry I will be asking more dumb questions,
    1) What is the purpose of the X axis bearing adj plates? Why is it in one side and not in both?
    2) Why are the holes in magenta (1/4") and blue (1/5") (see image) of different diameters? Should't they be the same as the same screw goes through them (1/4")? Won't it damage the MDF or HDPE piece as the hole is smaller than the screw?
  15. #215
    Aug 2004
    3215
    the ones in blue look like they are for tapping 1/4" to it should be around 0.19", Also the antibacklash nut housing is only for acme nuts if you are using them, if you ate using dumpster delron nuts you do not need them.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  16. #216
    Aug 2015
    38
    I have one more question: how do you get this hexagonal recessed holes to not have round borders? As far as I know inner recessed holes would have round borders if cut with a CNC.
    Attachment 291908
    Sorry again for the dumb question.
  17. #217
    Jul 2012
    43
    As far as I know you do the final pass with a very small tool or you can use a sharp chisel
  18. #218
    Jul 2012
    43
    Every time I try to download the viewer I am told that I need a full subscription?????
    I am using a Windows PC not a mobile device.
  19. #219
    May 2015
    1422
    Quote Originally Posted by Wolffie View Post
    Or look at a rotary broach form tool to get it spot on.
    If it's to take a hex head, you could also put circles (maybe pre-drill?) the corners so the sharp edges fit in.
  20. #220
    35538
    That's what I do. Use a 1/8" bit and drill holes in the corners for clearance.
  1. Joes CNC Model 2006 in Vancouver, Wa
    By flyon in forum Joes CNC Model 2006
    Last Post: 10-14-2015, 01:17 AM
  2. Joes CNC Model 2006 R-2 plans and edrawing dimensioning
    By javarik in forum Joes CNC Model 2006
    Last Post: 09-26-2010, 02:11 AM
  3. Selling a Joes CNC Model 2006 R1
    By finless139 in forum Joes CNC Model 2006
    Last Post: 04-30-2010, 03:26 AM
  4. Joes CNC Model 2006 in metric
    By pklecz in forum Joes CNC Model 2006
    Last Post: 12-10-2009, 01:23 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
