588,202 active members*
4,169 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Fagor 8055T how to pause program execution?
Results 1 to 10 of 10
    Apr 2015
    5
    I am new to fagor 8055T. Is there any way to temporarily stop a part program execution then resume it later?
    Mar 2015
    4
    Yes, Before you restart the program, you have to find the block.
    Jan 2004
    3154
    Re: Fagor 8055T how to pause program execution?
    Pushing the red button puts it in halt mode, will resume on green button push.
    If you mean a consistent stop in the middle of a program for tool check or measure or...... add the Gcode "M00"
    www.integratedmechanical.ca
    Apr 2015
    5
    I want to open the door and clean the chip, but once I do so. the program ends and I must do block search stuff ....
    Apr 2015
    5
    yeah. I must do block search and find the block where the machine stopped. I am looking for pause - resume thing if there is any. Tq
    Jan 2004
    3154
    What happens if you try a "tool check"?
    - Pause program using red button
    - press "T" (now you are in check mode and can even jog machine out of way if you want)
    Apr 2015
    5
    I pressed the red button
    then " Tool Inspection"
    but when I open the door to clean the chip, an error message pops up.
    when I close the door and choose Esc or Main menu. in both cases if I press the start button , the program starts from beginning not from where it was.I s there a way to preserve the program stop point and resume it after cleaning the tool?
    Apr 2015
    Hay all need your help.
    Acer knee mill with Fagor control Model is a BED-1050 Acer. Not sure on the Model of the control yet.
    Mach has Glentek SMA7110-04b-005A-1 drives. Getting AL 2001 X aixs feedback error.
    Dec 2011
    73
    Quote Originally Posted by Mofd-cat View Post
    It's probably an 8055i model. You should start your own thread for your specific problem.
    Dec 2009
    88
    Quote Originally Posted by kensh View Post
    If you have not figured it out by now. But if you press cycle hold then press the "t" key then you can jog and stop the spindle. Where your done jog the tool close to where it was when you stopped it and press cycle start and the screen will prompt you to get the program going again
  1. Fagor 8055T
    By wht_brd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-02-2014, 04:10 PM
  2. Fagor 8055T issue.
    By birdman3131 in forum Fagor Automation
    Last Post: 06-24-2013, 08:56 PM
  3. Help with my Fagor 8055T
    By Boxhead in forum DNC Problems and Solutions
    Last Post: 04-12-2012, 06:09 AM
  4. Help required Fagor 8055t
    By MAINTAINERS in forum Fagor Automation
    Last Post: 01-27-2009, 07:21 PM
  5. Fagor 8055t
    Last Post: 11-09-2006, 02:38 PM
