587,743 active members*
3,211 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Suitable tolerance between parallel linear shafting ?
Results 1 to 6 of 6
    Mar 2014
    16
    Anyone know what the suitable linear tolerance between 25mm parallel shafts would be for use with adjustable quality linear ball bushings ?
    Cheers
    35538
    Re: Suitable tolerance between parallel linear shafting ?
    If it's not very near zero, you'll experience binding as it travels from one end to the other.
    Mar 2014
    16
    Thanks Ger21. Do you think 0.05mm be ok ?
    Jun 2010
    4262
    Can you get 50 microns free play in a good ball race?
    Didn't think so.
    I would be looking for not over 5 microns, myself. But one normally gets that or better by sliding the carriage back and forth as the bolts are tightened.
    Cheers
    Roger
    Aug 2004
    782
    Rcaffin has it right.
    Apr 2009
    5516
    Check the spec sheet from the manufacturer. Depending on grade, they have a parallel as well as on-plane tolerance which I'd a bit higher than one may think. Obviously you want them as perfect as possible but that is not always possible
  1. Supported rail linear shafting....
    By toofdecay in forum DIY CNC Router Table Machines
    Last Post: 11-09-2011, 01:21 AM
  2. Couple questions linear shafting
    By justCNCit in forum Linear and Rotary Motion
    Last Post: 06-17-2008, 02:30 AM
  3. linear shafting
    By dandydon in forum DIY CNC Router Table Machines
    Last Post: 12-27-2007, 02:23 AM
  4. Drilling Thompson Linear Shafting
    By MikeAber in forum MetalWork Discussion
    Last Post: 08-19-2005, 12:51 PM
  5. Nylon Linear Bearings and shafting
    By Jcadwell in forum Community Club House
    Last Post: 04-15-2004, 02:29 PM
