587,541 active members*
7,891 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Tool Post Block G4003 12X Lathes
Results 1 to 12 of 12
    Jan 2009
    234
    See a Few conversions with a Block in place of the compound slide to make the tool post more ridged. Anyone have the plans for this block?
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
    Jan 2009
    234
    Re: Tool Post Block G4003 12X Lathes
    Been Playing With Autocad!
    I am Thinking this will work for an ultra ridged tool post block to replace the compound slide that has a lot of flex. Not 100% Sure of the location of the center hole or the thread pitch as I do not have the tool post off the compound slide. Figuring in steel it will weigh about 14-16 lbs not sure if it will be to heavy I know a 6 tool ATC Weighs 30lbs and people use them on this lathe. I Could go aluminum but not sure I would trust aluminum's longevity.
    No a good source to obtain a 3" thick 5" W X 6" L chunk of steel may pose a problem. I made it a tad bit shorter on the height about .125 so the over size BXA holders will allow the use of up to 1" insert holders.
    I have the mounting bolts at 1/4″ may bump them up to 5/16″.
    Any Advice? or is this over kill?
    Aug 2008
    962
    Isn't 3/4" the largest tool shank a BXA holder will handle?
    Jan 2009
    234
    I think Dorian made some that hold 1"
    Searched fee-bay seems 2.5" X 5" X 6" 6061 out of Colorado with freight is cheaper then steel here and 1/2' the cost of 6061 here. I need to find a good source of materials locally. The yards here do not like small orders and can take 3-4 days to get any thing cut.
    Jul 2014
    14
    Quote Originally Posted by gd.marsh View Post
    Generally it is 5/8" IIRC
    Jan 2009
    234
    The XL holders are 3/4" shank. they are a bit larger also about 3.5" in length not 2.5"
    Apr 2007
    157
    If you are going to make a ToolPost Block for your Lathe you need to make it to adapt to your QC Tool holder.What i mean is it should have a T Slot machined in it to accomidate the QC Tool Holders Mount. The reason for the T slot is so that I could move the Post out to turn Larger OD's...I used existing holes from CrossSlide Mount and made the block..4.312x4.0x1.562.
    I am able to turn 12.250 Delrin with PieJaws And A Bison 5" 6jaw chuck and a boring bar.....innovatieve tooling solutions :-) Every CNC Lathe that I have ran,including the ROMI M20 that i run now @ work has that style of TP Block...if you make a rigid one you are pretty much stuck in a rut..
    Jan 2009
    234
    That is a good point I will see if i can figure out how to draw up a T Slot
    Apr 2007
    157
    See if you can Open this???
    Jan 2009
    234
    It open but bunch of colored lines can kind of make it out.
    Apr 2007
    157
    OK well it is drawn with Colors for a Purpose..The Magenta lines are the OD of the TSlot 2.25 x .515. The Yellow are for a Pocket PGM. that cuts the 1.25 x .855 Center...this is all for my C6..I am going to my shop now I have things to do....I will take a picture and see if i can upload it with my phone..
    Apr 2007
    157
    Here are the pictures.
  1. Tools and Extras for a Grizzly G4003
    By 65Cobra427SC in forum Uncategorised MetalWorking Machines
    Last Post: 03-30-2015, 07:24 PM
  2. Replies: 1
    Last Post: 09-21-2012, 08:21 PM
  3. Replies: 0
    Last Post: 02-17-2012, 08:19 AM
  4. Grizzly 12x36 G4003 lathe and tool post grinding
    By ThePigStye in forum MetalWork Discussion
    Last Post: 07-23-2010, 03:33 AM
  5. Quick Change Tool Post for 7x10 Mini Lathes
    By widgitmaster in forum Mini Lathe
    Last Post: 07-14-2009, 10:01 PM
