587,761 active members*
3,181 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Error: spindle lubricationn distributor
Results 1 to 18 of 18
    Apr 2009
    34
    Re: Error: spindle lubricationn distributor
    If this machine has the "High Speed" spindle option the it will have two lubrication tanks on the back of the machine. The tank on the right is for the high speed spindle option. There is a pressure switch directly above the tank. This switch could be defective. If you let me know machine serial number, I can check what options it had. It could be that this is not a high speed spindle but the option parameter is turned on. The only time it looks at this pressure is at a tool change. The air that is supplied for the spindle air lube mist goes through two filter/drier units that are located by the air supply for the machine,they are in a housing and marked change 6 month and change 1 year. They are made by Laman and look like the size of two cigars.Also on the top of the machine there should be a mixing block that is made of aluminum and has a lube line and an air line going in and 3 or 4 lines cumming out going to the spindle head. Let me know machine serial number for further assistance.
    Jeffrey Kale
    General Manager
    CYBER CNC MACHINERY SALES,INC.
    S86 W22400 Edgewood Avenue
    Big Bend, WI 53103
    Phone: (262) 662-1100
    Jun 2015
    42
    Thank for a promt response!
    I will check it tomorrow for SN but it does not have a High speed spindle, due to my spindle revs are 8500 per minute. An as far as i know (i'm not in shop right now) - it has only one tank with the fluid.
    Do you have manuals for sale for my machine?
    Jun 2015
    42
    Hi again,
    my SN is T1125704
    Apr 2009
    34
    Serial Number should start with VK47_ _ _ The number is on a Tag usually says Model Number then Serial Number
    Jeffrey Kale
    General Manager
    Big Bend, WI 53103
    Jun 2015
    42
    Quote Originally Posted by CyberCNC View Post
    Yeap, sorry, sn is 47103
    Apr 2009
    34
    It is apparent that this machine was not sold in the Americas. I only have records from Hitachi Seiki of machines that where sold here. I do not know what control is on this machine, nor do I have a list of what options this machine has. If you can tell me the control and the alarm number, I may be able to tell you what parameter may be causing your problem.
    Jeffrey Kale
    General Manager
    Big Bend, WI 53103
    Jun 2015
    42
    Thank you,
    the control number is T1125704 . It has Seicos M-3. But i think i have found a problem:
    I've checked the oil level in that rear tank and it was present, but i have mentioned that a level indicator is empty, so i think that the level is not enough - i have marked the present level with a red line. And what oil should i fill
  1. mazak VQC-15/40 - Spindle error
    By john robertson in forum Employment Opportunity
    Last Post: 07-27-2016, 08:03 PM
  2. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  3. error 136, spindle interlock... on and off?
    By OptionCNC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2012, 07:49 PM
  4. Mazak QT-20 HP Spindle Error
    By Carnedude in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-15-2010, 04:29 PM
  5. Fanuc 6T spindle error
    By ABT in forum Fanuc
    Last Post: 08-04-2008, 02:18 AM
