588,500 active members*
5,355 visitors online*
Thread: XZero CNC
Page 209 of 226 109159199207208209210211219
Results 4,161 to 4,180 of 4515
  1. #4161
    Dec 2010
    634
    Re: XZero CNC
    Anyone happen to know what brand of lovejoy style coupling George is using? I'm changing my drive motors and they've got 8mm shafts so it would be great if I didn't have to remove the ballscrew half of the connector.
    I've been trying to get in touch with George but he's been off the grid for like two weeks now.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  2. #4162
    May 2008
    4068
    Re: XZero CNC
    Quote Originally Posted by BanduraMaker View Post
    Hi Andy , I sent you email that I don't have in 8mm for the 30mm OD coupling on your long axis. I only have 12.7mm and so older 6.35 couplings. I do have 8mm in 25mm OD but asked if yours was 4 tooth or 2 tooth
    XZero cnc
  3. #4163
    May 2008
    4068
    Re: XZero CNC
    Mini detail rendering
    Attachment 294324
    XZero cnc
  4. #4164
    May 2008
    4068
    Re: XZero CNC
    XZero cnc
  5. #4165
    May 2008
    4068
    Re: XZero CNC
    XZero cnc
  6. #4166
    May 2008
    4068
    Re: XZero CNC
    Lots of great info on making pool cues on this YouTube channel
    https://youtu.be/eVSZOK1DK1s
    XZero cnc
  7. #4167
    Dec 2010
    634
    Re: XZero CNC
    Quote Originally Posted by gio666 View Post
    Hi George,
    I never got any e-mails from you, checked my spam folder and everything. Try sending another and I'll try to call you as well.
    -Andy B.
  8. #4168
    Jul 2015
    3
    Re: XZero CNC
    What are the product numbers?
    Where can i buy some of these... they are WAY COOL!
    SirDag
  9. #4169
    May 2008
    4068
    Re: XZero CNC
    Quote Originally Posted by SirDag View Post
    SirDag
    Are you asking 4th axis part number?
    XZero cnc
  10. #4170
    May 2008
    4068
    Re: XZero CNC
    I have been asked lots of times for bare frames for sale. I will be selling them as bare kit without blocks/rails or ballscrews.
    For people wanting to use lower cost blocks and rails, like Hiwin or other companys out there or lower cost ballscrews
    Bare Frame kits for DIY
    XZero cnc
  11. #4171
    Jul 2012
    86
    Re: XZero CNC
    Hey everyone. . Quick question for you all. I started making a simple fence picket with one 2d contour.. I'm using hsmexpress for solid works. . Love the integration for cam programming. The machine cuts the contour and then always travels home or in that direction. Mastercam used to push the same result. It travels all the way to the back of the machine until it hits the limit switch. However i made 10 pieces and each one is just under 1/8" shorter than the one previous. Has one ever experienced anything like this? How can I solve it? I have another 120 pickets to make and don't want to have to re zero each piece as i gave a jig made.
    Thanks in advance
    Rob
    Sent from my SM-G900W8 using Tapatalk
  12. #4172
    May 2008
    4068
    Re: XZero CNC
    Quote Originally Posted by Padrino View Post
    Thanks in advance
    Rob
    I don't know what ballscrews or what you used.
    You might be missing a step somewhere . Even missing step it will go to limit switch no matter how many steps you lose.
    Are you running servos? or steppers?
    XZero cnc
  13. #4173
    Jul 2012
    86
    Re: XZero CNC
    I found the problem last night. Turns out the home position was set in machine coordinates to a position not on my table so every time I finished a program it would end up tuning to the end of the machine where it hit the limit switch. On top of that I found the limit switch loose and the machine was actually hitting the hard stop just before the limit switch. All is good now. Thanks machine runs like s dream now that it's finished.
  14. #4174
    May 2008
    4068
    Re: XZero CNC
    Have new pricing on easyservo kits for machines.
    Easyservo and integrated easyservo
    XZero cnc
  15. #4175
    May 2008
    4068
    Re: XZero CNC
    New High speed stepper motor from leadshine for MX3660 or MX4660
    XZero cnc
  16. #4176
    Jul 2012
    86
    Re: XZero CNC
    Interesting!!!
  17. #4177
    May 2008
    4068
    Re: XZero CNC
    Wiring comes with easyservos .
    Attachment 295134
    XZero cnc
  18. #4178
    May 2008
    4068
    Re: XZero CNC
    Settings for integrated easyservo
    XZero cnc
  19. #4179
    Sep 2014
    64
    Re: XZero CNC
    George as I am new to servos (heck, still new to steppers), let me ask a dumb question. Does each easy servo have its own dedicated ES-D508 drive? If so, can you add an easy servo with an ES-D508 to a Leadshine MX4660, say if you need ultra precise rotary axis control, or do you need to completely change your machine over to 100% servos?
    Thanks for your patience with the newbie stuff...
    John
  20. #4180
    May 2008
    4068
    Re: XZero CNC
    Quote Originally Posted by JohninOttawa View Post
    John
    Hi John, you might be able to use 5th or 6th axis output on MX4660 or 4th axis out put on MX3660 , I ll have to ask them to be sure but I think you can
    XZero cnc
  1. XZero CNC
    By gio666 in forum News Announcements
    Last Post: 04-30-2013, 05:53 AM
