587,524 active members*
3,485 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Chronicle of a Geek! (Part 2 A new dawn)
Page 9 of 9 789
Results 161 to 172 of 172
  1. #161
    Aug 2005
    437
    More tweaking, increased the table base to 1.5" thick, added T-slot tracks, and 3/4" thick strips between T-slots, I'll skim cut this to level the table later.
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
  2. #162
    Aug 2005
    437
    Started work on dust collection, making parts for the shoe.
    Attached Thumbnails Attached Thumbnails IMG_20150322_194918824.jpg   IMG_20150322_194930487.jpg
    Deeds not words...
  3. #163
    Aug 2005
    437
    Had a little shop time, painted the main from of the shoe, and cut the rear filler/vac attachment plate. Now need yo come up with an adjustable mount.
    Deeds not words...
  4. #164
    Apr 2009
    5516
    Re: Chronicle of a Geek! (Part 2 A new dawn)
    Looking good.....
  5. #165
    Aug 2005
    437
    Thanks Louie. It's been a long time getting to this point. The dust shoe is almost complete and then I guess I'll have to make something...
    Or start another machine ;-)
    Deeds not words...
  6. #166
    Aug 2005
    437
    First engraving test
    In this first test I am using a 60* V bit .125 Dia. The code was to cut .015 deep in .003 steps down. I started the cut about .007 above the surface to watch the path. The actual engraving is only about .008 deep.
    Deeds not words...
  7. #167
    Aug 2005
    437
    Engraving test 2
    On this run I changed the code to make 2 passes, first .008 deep second finished it at .015 deep. At this depth I lost a lot of detail.
    Lesson Learned: When prototyping in MDF I can run a single pass at .005 to .007 this saves time and detail.
    Deeds not words...
  8. #168
    Aug 2005
    437
    I would like to try this on a thin plywood, I have concerns with tear out. Would it help if i give it a coat of poly or spray on acrylic first? or between passes to keep the small pieces from popping out?
    Deeds not words...
  9. #169
    Aug 2005
    437
    The answer is NO! the tiny parts still pop out. :-(
    Deeds not words...
  10. #170
    Aug 2005
    437
    Still working on acquiring some knowledge and skill in the use of engraving bits. I find I learn more when I have an actual task to perform. So I decided to make some custom engraved cutting boards for friends I have on the lake. I got the bathometric data from my states website, (Tax dollars at work). It was available free as a PDF, I imported it into inkscape and converted it to DXF. Opened the DXF in my 2D CAD program and did a bit of editing/scaling. Converted the DXF to gcode in Cut2D and output to Mach3.
    Deeds not words...
  11. #171
    Aug 2005
    437
    More....
    Deeds not words...
  12. #172
    Aug 2005
    437
    And the final results....
    Deeds not words...
Page 9 of 9 789
  1. cant get rid of solidcam from a part created internally within the solidworks part
    By Nava in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-24-2013, 01:05 AM
  2. RFQ for part to mount on picatinny rail and sheetmetal part
    By JAW in forum RFQ (Request for Quote)
    Last Post: 08-23-2012, 02:00 PM
  3. Chronicle of a Geek. (Jgro Build)
    By voltsandbolts in forum Commercial CNC Wood Routers
    Last Post: 06-18-2010, 01:45 AM
  4. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
  5. "You might be a computer geek if..."
    By HogDog in forum Community Club House
    Last Post: 01-10-2006, 02:58 PM
