588,548 active members*
5,528 visitors online*
Results 1 to 3 of 3
    Jul 2004
    13
    UCCNC & UC300
    Hi guys,
    i've problems to find the correct configuration and wiring for the classic limit switch.
    I don't understand which function is need to set in "INPUT TRIGGER" window to stop an axe when the limit switch is pressed.
    Someone ca suggest me the right way?
    Thanks to all.
    Vincenzo
    Oct 2005
    1145
    Re: UCCNC & UC300
    Go to teh config screen then select the axis you are working with. You willl see a setup box for limit+ ,Limit - . Input the values for the Pin and Port of the UC300 that you are going to use . Then select either active high or low to match your switch arrangement . Apply and Save the settings and you should be good to go.
    (;-) TP
    Jul 2004
    13
    Re: UCCNC & UC300
    I'm very stupid!!!!!
    I don't know because i've searching in the "INPUT TRIGGER" windows!!!!
    Many thanks.
  1. UCcnc / UC300 with ATCs
    By vmax549 in forum UCCNC Control Software
    Last Post: 05-12-2018, 01:47 PM
  2. UCCNC and UC300 disconnecting
    By nicubila in forum UCCNC Control Software
    Last Post: 11-11-2015, 11:27 AM
  3. UCcnc /UC300 and RIGID tapping
    Last Post: 08-16-2015, 07:24 PM
  4. UC300 interface
    By bickius123 in forum News Announcements
    Last Post: 09-19-2013, 07:44 AM
  5. UC300 motion controller!
    By dubble in forum News Announcements
    Last Post: 07-03-2013, 04:12 PM
