Re: Speeds and Feeds confirmation
Originally Posted by
MetalShavings
....I deliberately measured the thickness of several of the Metal Shavings that flew off of my metal stock. Out of curiosity, I wanted to see if they were actually .015" thick...From these measurements I deduced that perhaps I needed to reduce the WOC
Like Ray said, WOC does not equal Chip Load (sometimes called Chip Load Per Tooth or Feed Per Tooth).
Chip Load = feed rate ( ipm )/( cutting rpm x number of cutting edges) --Note: usually this equation is solved to calculate feed rate based upon RPM and CL.
The tooling manufacturer generally recommends a CL based upon material and cutter diameter. This CL is chosen to maximize insert life, and prevent tool flexing/breaking. For example, in aluminum, a 0.5" endmill generally gets a recommended 0.004" CL, and a 1" endmill gets 0.007".
NOTE: If WOC when edge milling is actually driving CL size, then that means your feed rate is way more than is recommended by the tooling manufacturers.
Here are some good examples
Harvey Tool - Speeds and Feeds Guide | General Machining Guidelines
Niagara Cutter Speed and Feeds
in review:
1. select rpm based upon sfm and tool diameter.
2. select feed rate based upon rpm, CL, material, and diameter.
3. WOC/DOC based upon spindle hp available (this is the calculation where HSM Advisor or G_wizard helps out, the previous two are child's play).
If your chips are too blue or your spindle is bogging down, don't reduce your feed rate. That will make smaller chips, which means your cutter will heat up more and die faster. Instead adjust DOC or WOC so less power is required.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
