587,827 active members*
3,216 visitors online*
Page 17 of 20 71516171819
Results 321 to 340 of 394
  1. #321
    Dec 2010
    226
    Re: Open Source V-Carving
    Quote Originally Posted by WillAdams View Post
    Interesting.
    Do you have a comparison, or rough feeling for how paths / smoothness would compare between identical source material presented as both DXF and TTF?
    I actually had a bit of difficulty getting a path into F-Engrave over the weekend and was considering just making it into a character in a .ttf --- presumably that would have been sub-optimal, but the new version would improve that result --- sufficiently that there's no reason to use a DXF? Or would a DXF still provide a smoother path / result?
    In the end the same input from DXF or TTF should give the same (or very similar) results. The problem that I am fixing is that curves in the TTF are currently being represented by 4 lines regardless of the shape of the curve. The new version will provide better curve representation (similar to how F-Engrave currently treats DXF data) .
    Scorch
    www.scorchworks.com
  2. #322
    Dec 2010
    226
    Quote Originally Posted by scott216 View Post
    Would this just be part of a new release of f-engrave, or is it something separate that needs to be installed?
    If you use the pre-compiled windows executable file it will be included in the next release. If you run on Linux or use the python source file you will need to update your ttf2cxf_stream executable.
    Scorch
    www.scorchworks.com
  3. #323
    May 2007
    35
    Interesting.
    I don't know about ttf's , but what I do when dealing with a difficult path is to print it 1 to 1 to a pdf. I then get a screen capture of the pdf so I'm left with an image.
    It's a convoluted approach, and the size isn't 100% accurate, but f-engrave processes the image much faster than a dxf.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  4. #324
    Dec 2010
    226
    In addition to smoother TTF output I am going to add some new cut types to the next version of F-Engrave. I am adding an option for doing pocketing with a straight cutter and an option for doing prismatic letters (or image) with a v-bit. The prismatic letters should allow for making v-carved inlays.
    Here is a picture of a couple of my initial test cuts (the lower block fits in the v-carved "N" on the upper left)
    Attachment 287178
    Here is a picture of my first attempt at an inlay. (Made from the parts in the previous picture.)
    Attachment 287180
    Scorch
    www.scorchworks.com
  5. #325
    Sep 2009
    15
    Looks fantastic I can't wait to try it.
  6. #326
    Dec 2010
    226
    I released the new version of F-Engrave and a video showing the process to make inlays. More information is available here: Scorch Works BLOG: F-Engrave 1.50
    Attachment 288096
    Scorch
    www.scorchworks.com
  7. #327
    Aug 2005
    437
    That looks really nice!
    Sent from my XT1080 using Tapatalk
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
  8. #328
    Dec 2010
    226
    I released a new version of F-Engrave (V1.51). The only significant change is the addition of a separate Plunge Rate. The Plunge Rate controls the feed rate when the tool is moving straight down into the workpeice. If the Plunge Rate is set to zero the normal feed rate is used.
    F-Engrave Download Link
    Scorch
    www.scorchworks.com
  9. #329
    Dec 2010
    4
    Hi, when using F engrave 1,51 i get the following result - i see a couple of lines (in the upper right corner there are three of them going from the middle line to the outer line) that don'*t look...Attachment 297874
  10. #330
    Sep 2005
    371
    I see this occasionally too. I just load the processed GCode and manually delete the lines of code. I've also ran the file with them there and really can't see a difference in finished results since the extraneous lines are ramping up and out of the valley anyway.
    Removing the lines of code (on my part) is only done to speed up the engraving process.
  11. #331
    Sep 2009
    15
    By changing the "Sub-Step Length" in the V-Carve settings you can control those little lines. In the first picture I used a sub step of 0.1mm and it gave the lines to the left but by increasing to 0.3mm all of the lines are gone.
    Attachment 297886
    Attachment 297888
    I have found that it is better to get rid of the lines as it gives a much smoother curve on the finished product.
    This is a much easier way to 'cleanup' the gcode rather then edit the code itself.
    As Scorch says in the manual re. Sub-Step Length
    "The v-carving algorithm steps along the font or DXF outline and performs tool location and depth calculations at a fixed interval. The fixed interval is the "Sub-Step Length" a large substep length will increase the speed of the v-carve calculation but could result in a more faceted looking v-carve. Reducing the "Sub-Step Length" too much can cause excessive calculation time and reduced CNC machine performance (due to excessive short G1 commands). If in doubt start with a larger step size and reduce the value until the results seem reasonable."
    Edward
  12. #332
    Dec 2010
    226
    Quote Originally Posted by lagore View Post
    Attachment 297886
    Attachment 297888
    Edward
    Nicely said Edward. One additional thing to note: If the extra lines are visible in the finished carving the F-Engrave setting for the v-bit angle is probably not exactly correct. Some v-bit angles are off a couple of degrees from what they are supposed to be (e.g. 58 degrees instead of 60 degrees)
    Scorch
    www.scorchworks.com
  13. #333
    Sep 2005
    371
    Good to know!
  14. #334
    Dec 2010
    4
    Hi, again me, sorry for beeing boring, but i can't make it. I tried with different values (see pictures) in the Sub-Step Length. And the v-bit angle parameter is the original from setup (90 degr. / 12.7 mm). thanks for any help - ThomasAttachment 298204Attachment 298206Attachment 298208Attachment 298210Attachment 298212Click image for larger version.
  15. #335
    Sep 2009
    15
    Can you upload the image and a can have a go at it?
    Edward
  16. #336
    Dec 2010
    4
    Hi Edward, thanks for your help. I tried 2 different ways. First as a bmp File (see attachment) and Second, i used the text mode in f engrave 1.51. I used the font "English Gothic, 17 th c.ttf". more ore less the same results... Thomas
    Attachment 298220
  17. #337
    Dec 2010
    226
    The .5mm and 1mm step versions above look good (from the screen shots). There is always going to be one tool path running from the edge of each "loop" or boundary of the image to the center of the cut. These are the entry tool paths for each cut. These entry tool paths are there by design so that the cutter does not plunge straight down into the material at the beginning of the cut. Plunging straight down into material with a v-bit can cause problems (i.e. bogging down or chatter) especially for weaker machines.
    Scorch
    www.scorchworks.com
  18. #338
    Feb 2013
    39
    Instructions on installing it on Mac OS X:
    1.Launch a Terminal.
    2.Make a directory to hold the final F-Engrave files: mkdir ~/Applications/f-engrave
    3.Make a temporary directory to work in if you don't already have one: mkdir ~/tmp
    4.Change to the temporary directory: cd ~/tmp
    5.Download the F-Engrave source from here F-Engrave
    6.Extract it to a temporary directory using unzip: unzip ~/Downloads/F-Engrave-1.52_src.zip
    7.Change to the extracted directory: cd F-Engrave-1.5.2_src
    8.Copy the F-Engrae Pythonfile to the final application directory:cp f-engrave-152.py ~/Applications/f-engrave`
    9.Change to the included tt2cxf source directory: cd TTF2CXF_STREAM
    10.Launch TextEdit and edit the Makefile in this directory to point to the proper freetype headers. Change the line g++ -o ttf2cxf_stream ttf2cxf_stream.cpp -lm -I/usr/include/freetype2 –lfreetype to g++ -o ttf2cxf_stream ttf2cxf_stream.cpp -lm -L/usr/X11/lib -I/usr/X11/include/freetype2 -lfreetype. You can also use vi in the Terminal if you're comfortable with it: vi Makefile
    11.Run make to compile: make
    12.Copy the new binary to the final application directory: cp ttf2cxf_stream ~/Applications/f-engrave
    13.Change back to the temporary directory: cd ~/tmp
    14.Download the potrace binaries for OSX from here Peter Selinger: Potrace
    15.Extract it to a temporary directory using tar: tar –xzf ~/Downloads/potrace-1.13.mac-x86_64.tar.gz
    16.Copy the extracted binary to the final application directory: cp potrace-1.13.mac-x86_64/potrace ~/Applications/f-engrave
    17.Change to your final application directory: cd ~/Applications/f-engrave
    18.Update your PATH environment variable to include this directory so F-Engrave can find potrace and tt2cxf. You’ll need to do this every time you launch the Terminal or add the line to your ~/.bashrc: export PATH=$PATH:~/Applications/f-engrave
    19.Run F-Engrave using Python: python ./f-engrave-152.py
    From: https://discuss.inventables.com/t/f-...e-on-osx/16187
  19. #339
    Dec 2010
    226
    Thanks Will, Looks like useful information for Mac users.
    I love how he mentions you can use vi for the text editing. If you are hard core enough to use vi no one needs to tell you it is OK.
    Scorch
    www.scorchworks.com
  20. #340
    Jan 2015
    138
    Scorch, first I continue to be amazed at how nice a job your software does. Thanks very much.
    I'm having some issues saving g-code. Here are a couple of scenarios:
    Load image, load existing g-code file. Change sub-step length in V-carve settings. Recalculate v-carve. Try to save--no save happens.
    Load image 1, load existing g-code file. Now load a different image that you want to use the same settings on. Try to save--no save happens.
    Is there a way to specify default directory for images and g-code?
    Thanks again,
    Steve
  1. Open Rail - open source linear bearing system
    By milatary56 in forum T-Slot CNC building
    Last Post: 06-09-2012, 02:07 PM
  2. OPEN SOURCE BLUEPRINTS?
    By denis6902 in forum Open Source CNC Machine Designs
    Last Post: 03-05-2010, 02:04 PM
  3. Open Source Cad Cam
    By kch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2007, 12:51 AM
  4. CNCPRO Open Source
    By Mits in forum Spanish
    Last Post: 06-07-2007, 05:04 PM
  5. Open Source Gecko 201 Look A Like?
    By pminmo in forum Open Source Controller Boards
    Last Post: 11-07-2004, 05:51 AM
