587,300 active members*
3,431 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > USB conversion file transfer
Results 1 to 5 of 5
    Sep 2006
    296
    Recently purchased a late '90's model lathe with an after market USB port added on. I can send and receive files to and from the port just fine but when i put the flash drive on a PC i cant see the files that were transfered to it. It works the same as the old floppy drives used to. Is there something im missing.
    Jun 2011
    68
    Re: USB conversion file transfer
    Late 90s? ... Try formatting the jumpdrive as a FAT instead of an NTFS (find that in the Format options)
    Sep 2013
    147
    If it is a floppy emulator. You need a program to format the flash drive to 1.4 mb. You may be able to do it with the machine.
    Dec 2011
    295
    The pathway isnt direct it is .....[ C:/program files/ emulator/ drive ¿letter?/ partition ¿number?/open] You cant go directly to the drive letter.
    Dec 2011
    295
    (D.P.)
  1. NX6 to CNC file transfer
    By keyancnc in forum UG NX
    Last Post: 01-31-2019, 10:13 PM
  2. Transfer file
    By Master Miller in forum Fanuc
    Last Post: 03-20-2011, 08:45 AM
  3. File transfer
    By Barrett in forum Okuma
    Last Post: 08-16-2010, 04:53 PM
  4. file transfer
    By valleyron in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-16-2008, 10:29 PM
  5. EIA file transfer
    By grunemh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-02-2005, 02:45 PM
