588,529 active members*
6,587 visitors online*
Results 1 to 5 of 5
    Feb 2015
    Fanuc 6T Mori Sl-1 parameters
    So I messed up good... I some how erased some parameters while trying to clear an error. Does anyone have a parameters list on their Sl-1 I can cheat from. No unfortunately I did not back up the parameters and yes I have learned my lesson. Also is there a list that describes what each parameter line does?
    Thank You
    Aug 2011
    2517
    Re: Fanuc 6T Mori Sl-1 parameters
    there is a list of 6T parameters in the back of the operator manual with descriptions. start there first, type them in then power off/on and see what doesn't work.
    you should try to get a proper backup from the same model machine. there could be a backup around on here too, its a common machine/control.
    Jan 2014
    3
    Quote Originally Posted by nperry View Post
    Thank You
    I have the parameters fanuc 6t -B
    Jan 2014
    3
    Quote Originally Posted by immi1919 View Post
    [email protected]
    Any time
    [email protected]
    Any time
    thanks
  1. Replies: 0
    Last Post: 12-23-2013, 06:02 PM
  2. Mori SL3 H Fanuc 10T F lost parameters and now almost runs well
    By rolandkra in forum Mori Seiki lathes
    Last Post: 07-11-2011, 09:01 AM
  3. mori-seiki TL1 Fanuc 6T parameters
    By shvavim in forum Mori Seiki lathes
    Last Post: 08-03-2009, 06:48 PM
  4. Replies: 3
    Last Post: 07-13-2007, 04:42 PM
