603,362 active members*
3,538 visitors online*
    Dec 2015
    NEED HELP TOOL PATH
    HI NEW HERE
    the problem im having is eg
    i make a drawing in torchmate cad-cam v9 and after i aply the toolpath ( tool path wizard) then export to the torchmate 4 machine driver program it doubles the cut path it cuts the same path twice
    need help thanks
    Aug 2015
    3
    Re: NEED HELP TOOL PATH
    I think that you may need to delete your original drawing lines from the file after making your toolpath.
    -Brian
    Dec 2015
    Quote Originally Posted by bfleeger View Post
    -Brian
    How do I do that
    Aug 2015
    3
    Here is a reference to walk you through creating the tool path on your drawing.
    The last step it covers is deleting the original drawing elements so you have only the tool path.
    Creating Basic Tool Paths | Torchmate
    -Brian
  1. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  2. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  3. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  4. Tool approach Tool Path
    By Kiwi in forum BobCad-Cam
    Last Post: 07-05-2007, 08:35 AM
