Originally Posted by
kstrauss
Actual thread form doesn't really matter since it will only need to mate with a nut that I will also be making. However, yes, I planned to use a normal V-form. That said, if I cut the internal and external threads with the same cutter I believe that the errors will be in opposite directions so rather than cancelling they will make the deviation twice as bad. Or maybe again I don't have my head cocked the right way!
As you mentioned, Z-travel will not be parallel with the part axis. In my case the threaded area is only about an inch long so with a 4.5-degree tilt the X-axis is only displaced by about 0.08 inches total or +/-0.04 inches over the length of the thread. My plan is to use a tooling ball to align the tilted 4th axis with the mill's spindle and a coordinated A/Z/X move to compensate for the tilt while cutting the threads.
Are you aware of any book or website that discusses issues such as thread milling high helix threads?
