588,533 active members*
8,845 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Thread milling issue. Machine pauses at end of every circle/loop.
Results 1 to 11 of 11
    May 2011
    18
    We are using an Emuge thread mill that cuts 1 thread per pass.
    Fanuc 31i.
    (Calling program has this line)
    N260 M98<TMMACRO2>L25(repeat 25 times)
    <TMMACRO2>(MACRO FOR THREAD MILL)
    N10 G91 G02 X0 Y0 I1 J0 W.125;
    M9
    This is a horizontal machine, The helical int. starts at the 9 0'clock position. Every time it completes a pass and gets back to 9 o'clock it pauses for a half second before starting the next one.
    We are just dry running this now, but I'm pretty sure these threads aren't going to look very good.
    Any ideas?
    Feb 2007
    314
    Re: Thread milling issue. Machine pauses at end of every circle/loop.
    it is not a macro call but a sub program call, may be your delay is due to exit en re-enter in the sub program.
    try to loop inside the macro instead of repeat the sub 25 time. Pass the number of loop in argument inside the macro
    example:
    G65 A25. P9212 (MACRO CALL WITH 25 PASSED IN #1)
    O9212(THREAD MILL MACRO)
    #2=0 (SET COUNTER TO 0)
    WHILE[#2 LT #1] DO1
    #2=#2+1 (INCREMENT COUNTER)
    END1
    M9 (STOP COOLANT IN YOUR SUB, YOU STOP COOLANT AFTER ONE TURN, NOT SURE IT'S WATH YOU WANT)
    Feb 2013
    21
    ezzywave
    The reason that it pauses is because of where your EOB is.
    Try this:
    N10 G91 G02 X0 Y0 I1 J0 W.125 M99;
    Feb 2006
    1792
    I believe Samu's method would work.
    Another (crude) way could be to simply copy/paste (repeat) the G02 line 25 times. It will have no overhead of any type.
    May 2011
    18
    Quote Originally Posted by Hardym1 View Post
    ezzywave
    Try this:
    Tried this. Still has the pause every circle. Thank you for the suggestion though.
    May 2011
    18
    Quote Originally Posted by samu View Post
    example:
    WHILE[#2 LT #1] DO1
    END1
    This worked!!! I had tried a similar sub (it had the same pause problem) with an "Increment Counter" like the yours, but I didn't use the DO WHILE function. BTW, the M9 should of been a M99, I did a sloppy cut and paste.
    I found another forum post that said said the pause is caused by acceleration/deceleration between circles that was caused by using logic.
    Now for my next question- How did you know this would solve my problem??? I was ready to write a sub with 25 lines of G2 moves!!! Not very convenient for different sized holes... I need to learn more about Fanuc "logic".
    Feb 2007
    314
    level change i.e. pass from main to sub, sub to main or sub to another sub take a signifiant amount of time, also the use of "goto" statement is to avoid if you don't want to have a pause. The goto function has to scan the program from the current block until the destination is found. Could take a lot of time if you jump a large amount of block. The use of the while loop solve that issue.
    Feb 2013
    21
    ezzywave,
    Glad samu idea worked out but I just remembered that it should look like this:
    M98P0001(whatever your sub program #)L25
    Sub program is:
    O0001G91 G02 X0 Y0 I1 J0 W.125 M99;
    NO EOB after your program number.
    Just ran it on my machine with no problem
    Feb 2006
    1792
    Hardym1,
    Had you observed the pause problem when M99 was placed in a separate block (which got corrected when M99 was shifted to the previous block) ?
    Feb 2013
    21
    sinha_nsit,
    No there was no pause when M99 placed in a seperate block, only when EOB was after the program #. I had the same issue years ago and remembered that it had something to do with where the EOB was. It's just that I have not done thread milling that way in many years.
    Feb 2006
    1792
    I do not understand why placing or not placing EOB after O-word should make any difference, as regards execution.
  1. Can I reduce this steel circle (motor) with my milling machine?
    By Micro Milling in forum Benchtop Machines
    Last Post: 12-23-2015, 08:10 PM
  2. How to retract Z when machine pauses.
    By cncgg in forum Techno CNC
    Last Post: 06-15-2011, 11:12 AM
  3. macro - motion pauses each loop
    By kendo in forum Haas Mills
    Last Post: 12-18-2008, 12:17 PM
  4. Maxnc 10CL 4 x 11.9" 1/10 HP Closed-Loop CNC Milling Machine
    By cadcamslawek in forum Benchtop Machines
    Last Post: 09-14-2007, 05:16 PM
