Thank you Tweakie.
Thank you Tweakie.
thanks larry.. what bits do you use?? and do you use old coins or blanks??
The bits I use for finishing are like this
10 x 0 5mm Titanium Nitride Coated Carbide Micro Drill Bits 1 8"" CNC PCB Router | eBay
I use a .1mm for roughing, running them as fast as I can with my router (25000rpm) and just watch the feed to see how fast I can push it. As for the material, I have used old pennies, old nickels and old dimes as they are just base metal (you know what you have). I have done a lot of aluminum engraving 'cause HDs look great with stuff on the cases and brackets. Hope this helps you.
One thing you need to remember is that with bits this small lubricant is a necessity and clearing the chips is a must, but be careful 'cause the brush can break the cutter! LOL
Larry
P. S. Practice and patience help, don't be afraid to try something,, the worst that can happen is your out $0.10 or so! :cheers: :cheers:
Can you do anything with this ?
Tweakie.
CNC is only limited by our imagination.
thanks, that should work
Ducks Unlimited.
Tweakie.
hi guys
am new here
I saw a file in .dxf for che famous photo
I just cant find it any more
if any body can help please
Is this any help (it is the cut-out for a vinyl sticker) ??
Tweakie.
Have anyone got any flame work in dxf or dwg that could share.
Thank you
As Larry has said, there are so many available if you just do a search. In the meantime here is one little one.
Tweakie.
thanx alot
i still didnt figure out how this wibsite work
so am sorry if my reply is too late
you have been so helpful
thanx![]()
Thank you.
This is the Che vinyl sticker cut-out from the .dxf file in my post #10792
Tweakie.
