588,293 active members*
4,186 visitors online*
Results 1 to 14 of 14
    Oct 2013
    185
    How to mill this part?
    I want to mass produce a part that has a rounded edge as marked in blue in the attached picture. I don't think it can be milled that way, but wanted to make sure that I'm not missing something? I could of course round it manually in a second operation, but that wouldn't be very practical since I'm planing on making 1000+ pieces.
    Attachment 304434
    Nov 2005
    201
    I'm thinking u would have to 3d mill it with a ball end mill or if u can set the job up in a 4th axis maybe a rad cutter
    Quote Originally Posted by cordvision View Post
    Attachment 304434
    Oct 2013
    185
    Re: How to mill this part?
    Quote Originally Posted by BIG IGG View Post
    Won't be able to 3d mill it. The radius is only 0.5mm so I can't get a ball endmill that small that has a long enough reach
    Jan 2007
    1795
    ONLY the blue part, looking very much like a sheet metal work..
    is there a thickness for?
    can you model separated you actually need?
    Oct 2013
    185
    Quote Originally Posted by victorofga View Post
    No, it's not a separate part. All needs to be milled from one solid block of aluminum. I just don't know how to do the area marked in blue (the radius of this rounded corner is only 0.5mm/.02").
    Feb 2009
    328
    Can you show a bit more of the part? It may be possible to use a small ball mill that has a form cut out of it to create that radius. What is the tolerance of the radius?
    Jan 2007
    1795
    oh I see
    then you need to use a endmill like 0.25 in dia, or 6 mm dia
    first you mill trough the ""opening""
    then on the radiused edge with same endmil you mill as ""horizontal finish""
    im sorry im not exact with process names..
    but same endmill, should make it..
    the endmill ""edge"" going forth n back along the radiused edge, and stepdowns following the radius..
    Dec 2012
    59
    The ways to accomplish this in one setup are pretty unattractive. As you've noticed, you need a very long tool with a relatively small diameter, and achieving a smooth finish will require very small steps. That makes for a very slow operation, likely slower then doing this as a separate setup on the same machine with a contoured tool, or as a post machining hand finish.
    Given the scale, unless this radius was tolerenced and critical, I'd form it with a deburring tool and/or a file after the part came off the machine.
    Oct 2013
    185
    Quote Originally Posted by Moggot View Post
    I thought that was the case, just had some hope that I might have missed an option that would allow me to do it in one set-up. The problem is that I have to do this feature on three sides so that amounts to three extra set-ups per part. I probably have to do it manually, I'm just worried that I don't get a nice finish without spending a considerable amount of time on each part.
    Jun 2014
    777
    You could use a straight shank tool holder with a small collet/nut to get a small ball mill down there, though you would only be able to go so far leaving the corners un machined.
    A 3D roughing of the chamfer with the same bit used to machine out first would reduce the amount of filling. Or could the part not be laid on its side?
    Nov 2013
    402
    Set up a second vise, turn the part 90° and use a normal corner-rounding tool?
    Run two vises in the same program, Op #1 and Op #2
    Jan 2007
    1795
    if that radius 0.5 mm then guessing from the scale of other elements you need a 6 mm dia tool about 20-25 mm out of chuck or collet..
    yes what visible on the picture you can make one setup
    outside might use a tronger tool like 10-12 mm dia to finish up the outside walls..
    the top of the wall can be radiuse with another tool
    saying more exact, could you post a picture how part looking?
    Mar 2008
    22
    Quote Originally Posted by RussMachine View Post
    I second this
    I would run two vise just as stated by russ and use a corner-Rounding tool
    Feb 2007
    1538
    A double corner rounding cutter will allow it to be cut in one hit - what are the different radii?
    Keen
  1. RFQ 1 Part, Mill
    By BillEVM in forum RFQ (Request for Quote)
    Last Post: 12-18-2013, 02:13 PM
  2. 5 + Hrs to mill this part ?
    By tubeguy in forum BobCad-Cam
    Last Post: 10-29-2012, 05:23 PM
  3. Yay! My first CNC mill and part.
    By alexccmeister in forum Benchtop Machines
    Last Post: 09-02-2008, 11:33 PM
  4. Part holding and milling 3D part on 2.5D Mill?
    By john_t_h in forum MetalWork Discussion
    Last Post: 03-15-2008, 12:35 PM
  5. RFQ - Part to be Mill or cut.
    By magnetos in forum Employment Opportunity
    Last Post: 11-10-2005, 02:00 AM
