588,206 active members*
4,317 visitors online*
Results 1 to 13 of 13
    Nov 2015
    25
    developed a fusion 360 script
    Hi all, I though I might try my hand at developing a fusion 360 script. It generates spur gears with a round root fillet (ellipse) to make machining easy (no corners to cut).
    Graham
    Nov 2015
    25
    Re: developed a fusion 360 script
    Opps, this shows it better Click image for larger version.
    Apr 2014
    432
    There are a number of free gear generators out there easy to use .
    Nov 2015
    25
    Yep absolutely (like Gear Generator), I couldn't find one that generated the curved fillets though.
    Still I know what you are saying - why re-invent the wheel? I guess the about box in geargenerator.com says it all. I'm building something fusion 360 and needed it.
    Interestingly enough, I read one article at suggested curved fillets make the gear stronger because the corner created a stress point.
    Jun 2010
    4262
    I don't know what that is meant to mesh with, but the teeth look a bit too big & fat to me.
    Have you tried printing that gear and its mate out on paper, cutting them out, and testing the mesh?
    Cheers
    Roger
    Nov 2015
    25
    Attachment 304500
    Hi Roger, just printed them out and ran them off a cordless drill at 1500 rpm. They work ok. The modulus is really high - 9mm.
    Nov 2015
    25
    The root circle is too small, I'll need to work on that.
    Jun 2010
    4262
    Yes, that's what I was thinking. Looks wrong.
    Have you looked at Gearotica?
    Cheers
    Roger
    Nov 2015
    25
    Yeah it looks great.
    Nov 2015
    25
    The undercut has been fixed by profiling the undercut.
    I want to prototype my design with some thin laser cut gears and add the cross for supporting lego, so I created a 2D laser cut version (the difference is that it adds a bit for the laser cut kerf).
    It is sure an interesting learning exercise. They make great spinning tops.
    It has been an interesting exercise in getting a script published in Autodesk. They (rightly) want a professional icon and a professional name. It is really interesting how we are going from expensive professional tools to the pricing model of Fusion 360. Brave new world.
    Jun 2010
    4262
    Rather a curious profile.
    Have you tried to do an FEA on the teeth? (Can Fusion do this?)
    Cheers
    Roger
    Nov 2015
    25
    Hi Roger.
    If FEA means finite element analysis, hmmm.
    Fusion 360 seems to have support for simulation etc, but I have never looked into it.
    What I am doing just has an end goal of creating gears out of pine (Douglas Fir) for an low power electronics project.
    Graham
    Nov 2015
    25
    My progress so far (3d printed, cnc routed and laser cut). The printed and cnc is using the undercut profile for the fillet (plus clearance), the laser one is not. I actually made a holder for the cnc version so I can cut one side, turn it over and cut the other. Challenge to get it out though.
  1. Mach 3, Developed by BobCad?
    By johnmac in forum BobCad-Cam
    Last Post: 08-22-2012, 04:54 PM
  2. developed view
    By NV529 in forum Solidworks
    Last Post: 06-26-2008, 01:28 AM
  3. Help! My X'1 developed an electrical fault!
    By digits in forum X3/SX3/G0619/G0463
    Last Post: 06-09-2007, 01:45 PM
  4. Replies: 5
    Last Post: 01-22-2007, 02:50 AM
