587,661 active members*
3,139 visitors online*
Results 1 to 6 of 6
    Jun 2014
    52
    Kurt Vise Issues
    Hello, I am posting in regards to an issue I am having with my CNC in keeping both vices linear to one another when holding a larger item (Larger parts require to remove the center pod). With the center pods pulled from each vice, it allows them to float freely; it seems one side is floating further than the other, and I am finding about a .010" taper off the back of my work-piece. Does anyone have any quick tips to control this? I feel silly asking I'm sure there is something I am doing wrong here. Any help is appreciated.
    "The one who follows the crowd will usually go no further than the crowd..."
    -Albert E.
    Mar 2008
    638
    Re: Kurt Vise Issues
    Are you talking about a double vise? If you are, my experience with Kurt 4" double vises is that the center bolted pod(?) is the stationary part and the outer movable jaws cannot be locked down so you will get it moving under load.
    If you're not talking about a double vise what's a "pod"?
    Jun 2014
    52
    My apologies on the description yes I am using a double vise with a center fixed "pod". I have 2 sets of double vises and was curious if I can maintain a good zero while having a part through both (without the center "pod"). Seeing as the center "pod" is used as a zero for the double vise, is it possible to remove this and keep accuracy while using both sets of vices? I hope this explained it a little better, don't hesitate to ask if something was ill described.
    -Albert E.
    Jun 2015
    6
    Quote Originally Posted by Cshade30 View Post
    in a word, no. two floating jaws need a solid piont.
    Jun 2014
    52
    Thanks you guys much appreciated!
    -Albert E.
    Nov 2011
    39
    On our Kurt HD6 double vices, we can lock the back moving jaw to a plate that is bolted to the back of the vice body. I made these special back plates out of aluminum and anodized them. if you look at the Kurt website i think they show these plates
    VF2, VF5, ST10, MINIMILL, MINIMILL2,
  1. Kurt Vise
    By cncbpt in forum For Sale Only
    Last Post: 02-23-2014, 12:46 AM
  2. Kurt D60 vise
    By ldeleon in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-09-2013, 11:16 PM
  3. Kurt Vise
    By Steve Seebold in forum Want To Buy...Need help!
    Last Post: 04-07-2009, 05:10 AM
  4. Home Made Vise Stop - For 6" Kurt Vise
    By widgitmaster in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2006, 03:49 PM
  5. Which Kurt Vise to get for CNC
    By JMFabrications in forum Work Fixtures / Hold-Down Solutions
    Last Post: 03-27-2006, 06:07 PM
