I recently setup my CNC 3040T and after some help from a user here got everything working...or so it seemed.
I found someone on upwork.com to make a design I created into Gcode. As soon as I loaded the Gcode into Mach3 and started the cycle my stepping motors make a loud sound. It seems they are trying to go past the bounds that the machine is capable of working on. Is this an easy fix? The design looks great from a Gcode standpoint; however, not sure if coordinates should be adjusted.
*This is my first time using the machine*
Any help would be greatly appreciated!
