I’m trying to control my coolant in mach3 with a solid saterelay from my output pins and have been unsuccessful so far.
I have Output Pins 1, 14 16 and 17 active in Mach3
Output 1 Port 1 Pin 1
Output 14 Port 1 Pin 14
Output 16 Port 1 Pin 16
Output 17 Port 1 Pin 17
I have check and unchecked active low settings on alloutputs.
The only pin that produces power is pin 16 (5 VOLTS DC)
With active low checked coolant comes on but wont cycle offwith Mach.
With active low X coolant is off and wont cycle on withMach.
I have the Disable Flood/Mist Coolant box unchecked
I have tested the relay with another power supply to makesure it does work.
Any sugestions?
