587,957 active members*
3,672 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Z axis Zero return not triggered during operation.
Results 1 to 7 of 7
    Aug 2010
    57
    My machine returns to z-axis zero just fine during the initial zero return process, but when I home during auto or MDI even though the ATC switch reads green it never triggers the z return position. I can't run the ATC without it. Any ideas? Is there a parameter I need to change?
    Dec 2009
    972
    Re: Z axis Zero return not triggered during operation.
    type of fanuc you have might help,and can you see the the tool change program?
    what alarm you have when you try to home by auto and mdi?
    Aug 2010
    57
    Sorry, Fanuc 0M-B.
    I don't have an error when I home, only when I attempt an M06, which brings back the 2025 Z-Axis is not in Zero Return Position error.
    Dec 2009
    972
    do you have in program the G30 Z0 line?
    Sep 2014
    37
    I'm not understanding the exact trouble you're having, but it sounds like from what you are saying that you either have a problem in your O9001 program (this is called by M06) or parameter 0737, which sets the return height. If the tool change program doesn't have a G30 Z0 in it that would cause it to not return to ATC height when M06 is called. If the parameter was wrong it would return to the wrong height. Hope this helps
    Aug 2010
    57
    G30 Z0 is present in the program.
    The problem is that the Z-Axis zero return is only triggered in zero return mode. Manually jogging it or moving it via program to z0 doesn't engage the light or apparently the switch.
    Feb 2007
    314
    it seems to me that your problem is more with the tool change thant with the zero return. Is your Z tool change is the same than the Z home? Also, you should have a switch activated at Z tool change height, not the same than the home switch whch in fact is deactivated at home position. If the z tool change switch is not activated (bad switch, bad wire, desajusted switch activator, or wrong parameter) you cannot perform tool change.
  1. Zero Return Problem with the Z Axis
    By PEDRORUIZCASTRO in forum Fanuc
    Last Post: 02-02-2016, 10:02 AM
  2. Need Help....Y and B axis won't zero return......?????
    By figurehead in forum CNC Swiss Screw Machines
    Last Post: 02-03-2015, 09:53 AM
  3. z axis return
    By vtg in forum CNC Machining Centers
    Last Post: 04-07-2012, 03:55 AM
  4. Axis' do not return to zero - creaping
    By Scott Kelley in forum Mach Software (ArtSoft software)
    Last Post: 05-09-2011, 11:24 AM
  5. Y axis over travel during zero return
    By kirby in forum Fanuc
    Last Post: 04-06-2011, 05:26 PM
