587,999 active members*
2,640 visitors online*
Results 1 to 6 of 6
    Mar 2016
    13
    Is my power supply the problem?
    I am currently having an issue where it looks as if my laser is not pulsing on and off. When it cuts a vector file rather than stopping the laser from firing between letters, for example, the laser continually fires connecting each letter with a burn mark. When attempting to etch a raster file the laser moved back and fourth but continually fires, obviously not etching the details of the file rather just a large burn area.
    The issue is not with the files as I tried this with many files i had successfully cut and etched prior and i also created new files that continued to have this issue.
    About 2 weeks ago i replaced the power supply and it was working correctly, I am thinking this new one already has gone bad.
    I am looking to order a power supply but want to make sure this is indeed the issue.
    Thanks,
    -Greg
    May 2015
    53
    Re: Is my power supply the problem?
    Quote Originally Posted by Devoreg View Post
    Thanks,
    -Greg
    I had this problem too ... I had called in TL and was to be on the TH ... After making the switch it worked normally ...
    Mar 2016
    13
    Quote Originally Posted by rodrigomartins View Post
    Thanks for the reply. Maybe a foolish question but what is TL and TH and how would I go about changing this?
    Jul 2014
    115
    TL and TH are input connections to the lasertube powersupply.
    On one of both connections the lasertube powersupply gets its signal to switch the laser on/off
    One of them activates the laser if the signal is high (voltage on), the other activates the laser if the signal is low (voltage is off)
    One of both (what one depends on the controller that connectes to it) has to be connected to the laser controller (on/off) putput.
    But I'am not quite sure if this could be your problem, as if so, the laser would not be switchable in general, so in your case it would fire as soon as the power is switched on.
    If it is a hardware problem, then it could be the PWM input of the lasertube powersupply, so the controller is able to switch the laser on/off but is not able to controll the power.
    The PWM is a connection from the controller to the powersupply, together with the (on/off) signal (TL or TH) it controls the lasertube. (one for on/off switch, the other for the laserpower)
    Best regards,
    Walter
    May 2015
    53
    Quote Originally Posted by Labmaster View Post
    Best regards,
    Walter
    Take a picture of how it is done connecting the controller cables to the Power suply so we can see ....
    Jul 2014
    115
    Where ise this blue, brown and black cables connected on the other side ?
    best regards,
    Walter
  1. Power supply problem
    By mondo50m in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-06-2012, 08:25 PM
  2. power supply problem
    By rashdan in forum CNC Machine Related Electronics
    Last Post: 02-28-2012, 08:30 PM
  3. DC Servo and Power supply problem.
    By Ark1 in forum Servo Motors / Drives
    Last Post: 10-19-2010, 02:08 AM
  4. TL-1 power supply problem
    By rideredcr in forum Haas Lathes
    Last Post: 09-03-2008, 07:48 AM
  5. ATX 2 power supply problem
    By flannman in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 07:19 PM
