588,167 active members*
4,939 visitors online*
Results 1 to 2 of 2
    Jan 2006
    7
    Mazatrol MT Pro
    Does anybody use Mazatrol MT Pro here..?
    It seems the controller doesn't like ARC shape (milling unit).
    We put the same number to our M64...it works just fine.
    I am just wondering if it happens to MPro machine too...
    We use Griffo MTPro DataEntry for offline programming...it fast and we can check the shapes using 3D view ( we imported the shape from SolidWorks to Griffo MTPro directly ).
    We can send the .pbb file If somebody want to try to put in their machine.
    Thank's
    Aug 2006
    62
    If you send the program to me I will give it a try we use Griffo. There are some Parameters you can change if the machine doesn't like the start or end point of a arc. Also if the arc is more than 90 degrees you could try breaking it up into 1/4's.
    Here is a new forum for Mazak Integrex machines. http://integrexmachinist.com/
