587,850 active members*
3,410 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > epoxy granite sliding on epoxy granite.
Results 1 to 20 of 23
    Jun 2010
    4262
    Re: epoxy granite sliding on epoxy granite.
    Disclaimer: I have zero knowledge of EG in practice.
    But, I rather doubt you need to remove the epoxy, and I strongly suspect that trying to do so would let some of the 'granite' fall out, either immediately or some time later. I would simply go diamond wheel for the lot.
    Just how well EG on EG would work - I haven't a clue. Sounds bad ... but you can get the surface really shiny smooth. Maybe pressurised lubrication?
    Cheers
    Roger
    Aug 2014
    889
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    My opinion is this would work so long as there's a film of lubricant between the two. Without it, I can see the re-plasticizing of the epoxy and subsequent weld together due to friction. I guess alot of it depends on the weight and pressure of the two surfaces sliding together.
    I too, don't work with EG, although I see it as a viable alternative to cast iron. This is interesting and if someone knows more, please enlighten us all.
    Mar 2009
    533
    The only machine I have seen that used granite was Excellon, and they used air, under pressure, as the "lubricant".
  1. Epoxy Granite Lathe
    By LazyH in forum Vertical Mill, Lathe Project Log
    Last Post: 04-02-2016, 06:48 PM
  2. A new epoxy granite CNC
    By muppy in forum Epoxy Granite
    Last Post: 07-02-2015, 11:46 AM
  3. Why is there so little going on in Epoxy Granite?
    By CaptainVee in forum Epoxy Granite
    Last Post: 06-23-2015, 03:28 AM
  4. epoxy granite
    By bebob1 in forum DIY CNC Router Table Machines
    Last Post: 10-30-2012, 11:25 AM
  5. Epoxy granite
    By slektning in forum Norwegian
    Last Post: 06-29-2011, 08:57 AM
